Old 07-11-2021, 08:28 AM   #12
midgetracer
midgetracer's Avatar
Default Re: FRONT model A ‘modern’ seal use.
I have used in at least 10 engines with great success. Now I have one that leaks, I am pulling the oil pan and replacing the seal later this month. I think the pan is the culprit in this leak. That seal that failed immediately and I am not looking forward to all the work to change it, as it requires lifting the engine after pulling the radiator etc. to remove the pulley. I am replacing it with another modern seal.
midgetracer is offline   Reply With Quote
