Old 07-10-2021, 01:49 PM   #1
hardtimes
hardtimes's Avatar
Default FRONT model A ‘modern’ seal use.
Anyone use this seal successfully ?
Old 07-10-2021, 01:55 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: FRONT model A ‘modern’ seal use.
I use the rope seal successfully.
Old 07-10-2021, 02:23 PM   #3
hardtimes
hardtimes's Avatar
Hey Patrick,
Tthanks, but I ask and need to know about whether others here can give me important feedback regarding use / efficacy of the modern front seal that is designed for possible better sealing at front of crank.
Old 07-10-2021, 03:24 PM   #4
Werner
Werner's Avatar
The modern shaft seal ("Simmering") can only be fitted if the entire front housing and the oil pan has been removed.
I also used the ropes mentioned by Patrick. When installed correctly, they provide a very good seal. There is only a slight oil mist on my car, always less than 1 drop. (The oiling out is much worse at the back of the crankshaft!)
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-10-2021, 03:28 PM   #5
chrs1961815
chrs1961815's Avatar
I have not used one myself even though I bought one to use on my engine rebuild but ended up keeping the rope. But I have heard (for what it is worth) that guys have had leaks with rope seals and modern seals with and without sealant. I think it all depends on installation and care not to damage the neoprene for sure. Some timing covers and oil pans have more sharp areas than others IMO.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-10-2021, 04:42 PM   #6
john in illinois
john in illinois's Avatar
I have used one for 28,000 miles in my Tudor. No leak yet. Put it in with black rtv.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-10-2021, 04:53 PM   #7
Werner
Werner's Avatar
John,
please tell me what is "black RTV"?
Werner
Citroen 11 CV, 1947
Old 07-10-2021, 05:16 PM   #8
alexiskai
alexiskai's Avatar
Permatex Ultra Black
Old 07-10-2021, 07:26 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Werner View Post
John,
RTV = Room Temperature Vulcanizing Silicon
Old 07-11-2021, 03:05 AM   #10
Patrick L.
Patrick L.'s Avatar
Originally Posted by hardtimes View Post
Hey Patrick,
I know, I answered because over the years I've read mixed results about this seal.
Old 07-11-2021, 06:17 AM   #11
Werner
Werner's Avatar
Thanks for infos!
Werner
Citroen 11 CV, 1947
Old 07-11-2021, 08:28 AM   #12
midgetracer
midgetracer's Avatar
I have used in at least 10 engines with great success. Now I have one that leaks, I am pulling the oil pan and replacing the seal later this month. I think the pan is the culprit in this leak. That seal that failed immediately and I am not looking forward to all the work to change it, as it requires lifting the engine after pulling the radiator etc. to remove the pulley. I am replacing it with another modern seal.
midgetracer is offline   Reply With Quote
Old 07-11-2021, 11:24 AM   #13
duke36
May want to look into the Stipes Specialty Motor Cams modern seal if using one. The original asbestos soaked ropes were reliable but no longer available. A smooth unpainted pulley shaft is essential.
Old 07-11-2021, 09:15 PM   #14
CWPASADENA
CWPASADENA's Avatar
It is imperative that the surface of the pulley that the seal rides on is absolutely smooth.
This is especially true when using a new pulley. The fine machining marks on the pulley will ware out the lip of the seal and cause it to fail prematurely.
I polish this surface when I assemble an engine.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 07-11-2021, 10:54 PM   #15
daveymc29
daveymc29's Avatar
I helped a friend put one in. He was told to not us rtv when installing it and it imediately leaked. We removed the seal and filled top and bottom with channel with rtv, pushed seal into place and it quit leaking. We used paper pan gaskets with a smear of rtv on the pan side only and torqued the bolts evenly, just tight. So far so good.
daveymc29 is offline   Reply With Quote
Old 07-12-2021, 09:21 AM   #16
Y-Blockhead
I bought a Stipes front seal to hopefully cure a front seal leak on my engine. Very nice piece but I have never used it. My seal leak was cured when I installed a balancer with a reverse scroll machined into it. Not a drop since.
http://www.specialtymotorcams.com/de...ront-seals-011
Old 07-12-2021, 09:39 AM   #17
nomadpsd
nomadpsd's Avatar
Hi Rick,
Look into the Stipe modern front seal. It uses an aluminum housing to hold the shape.
nomadpsd is offline   Reply With Quote
Old 07-12-2021, 09:25 PM   #18
SteveB31
SteveB31's Avatar
I’ve used over 300 of them on our engines. Had a couple leak, all the rest have not. Must use a new or very smooth pulley and be sure it Is centered and held in place with Ultra black.
SteveB31 is offline   Reply With Quote
Old 07-12-2021, 10:52 PM   #19
duke36
Any preference or results for a 1 piece vs. a 2 piece pulley ? Are the threaded type 2 piece pulleys acceptable as well?
Old 07-13-2021, 03:53 AM   #20
chrs1961815
I would only go with 1 piece pulleys - it seems the 2 piece pulleys coming apart is a real problem.
