Old 07-04-2021, 03:15 PM   #1
Tom in TN
Tom in TN's Avatar
Default Re: 272 Y-block oil leak- need help quick- show time
Originally Posted by Daves55Sedan View Post
I wouldn't do that. The older, quality adaptor plates are stamped of 12 gage? metal, so you wouldn't be able to take off too much before drastically weakening the filter gasket surface.
Years ago, I had an original adaptor plate on my spare Y-block that actually had a noticable dent in the gasket surface. I found a large piece of heavywall pipe that had been cut off square, set the adaptor plate upside down on a clean flat surface. I set the pipe on it and a wooden block on top of the pipe and blasted it with a sledge hammer. It popped the dent right out. I used that y-block with that adaptor plate for many years without any leaks.
I'd hate to think what a machine lathe would do to one of the cheap Chi-Com repro plates made of paper thin metal. Heck, they might be easy enough to cave in by tightening the spin-on filter too tight.
Question, was the original FOMOCO adapter arrangement a "2-plate" solution?
Does this sound correct for a Ford set-up? "Ford Y-block 239 256 272 292 312 OEM Oil Filter Plate & Adapter Spin ON Adapter Comes with all the hardware gaskets in photo need replacement. This is the OEM canister plate and adapter ,and than the spin on plate and adapter that screw into that"
Pic shows 2 plates...was it?
Tom in TN is offline   Reply With Quote
Old 07-04-2021, 04:20 PM   #2
KULTULZ
KULTULZ's Avatar
Question Re: 272 Y-block oil leak- need help quick- show time
Does this sound correct for a Ford set-up? "Ford Y-block 239 256 272 292 312 OEM 1) Oil Filter Plate & 2) Adapter - Spin ON Adapter Comes with all the hardware gaskets in photo need replacement. This is the OEM canister plate and adapter ,and than the spin on plate and adapter that screw into that"
What picture are you referring to?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
