Old 05-09-2021, 11:22 AM   #1
katy
katy's Avatar
Default Re: Cylinder head questions.
Originally Posted by alexiskai View Post
Probably he means don’t chase them with a tap.
I assumed that's what the OP meant, but, "why not"?
What's wrong w/a bottoming tap to chase/clean the threads?
Old 05-09-2021, 11:31 AM   #2
Y-Blockhead
Y-Blockhead's Avatar
Because a tap removes metal. Use a thread chaser or an old bolt with a slit cut in it. I never use a tap to chase threads.
Old 05-09-2021, 08:50 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I know where you are going but that is kind of a 'Misconception'. A tap doesn't necessarily remove metal. I use a tap to chase threads all the time as I am interested in removing damaged threads and/or rust. The reason why this myth about not using a tap is often mentioned is because most mechanics do not understand about classification of threads. Since I purchased the print of the engine block, it provided the class of threads. I ordered the matching class of bottoming tap, and it works perfectly.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
