I replaced the 7118 and 7121 bearings in my transmission with the current production bearings from a major parts supplier. They were the Chinese bearings. 1,200 miles later they failed. Looking for a source to get good bearings that will last. Any help will be appreciated.
Thanks! |
Brattons
As far as I know, the only thing available from most of the suppliers are still the junk bearings. However, a couple of months ago I purchased the 7121 bearings from, of all places, MAC's and they were the good 7121 bearings. I have no idea if they still have them but they might. The shorter bearing is hard to find, but you might call Steve Becker at Bert's Model A in Denver. He might even have some good used ones which are far preferable to the junk currently available.
#4 | |
![]() Quote:
Many of the suppliers were not even aware a switch was made. Those that are aware say that is all that is available. This is probably the greatest dis-service ever done to the Model A kingdom. It is not a question of they may fail, they will fail. I don't think anyone is making a quality bearing. See the attached.
Tom Endy |
I'm hunting for cross numbers for these and not having a lot of success. |
#7 | |
![]() Quote:
I'd be willing to take a crack at ID'ing substitute possibilities if someone can post the specs.
Mullet,
It was noise in the tranny. Came in all of a sudden. Rattled it home and into the shop. Pulling it tomorrow night (I hope). |
Thanks for all this info on the trans bearings. I was going to rebuild my spare transmission
this coming month. I will see if I can cross these numbers for good bearings. Thanks again, John |
A 1947 cross reference I have says the RA-135 Bower is the same as B7118 along with 99026 Hyatt, the B7121 is RA-136 Bower and 99028 Hyatt. Us V8 guys are having the same problem! I'm putting together two transmissions and using nice used bearings even though it goes against everything I learned over the years! Hope this helps, Dale.
#13 |
#14 |
Try Van Pelt or Michael at 3rd Gen Auto.
Paul in CT |
#15 |
Please let me know what you find. I'm having difficulty getting some that are American made.
#16 |
#17 | |
![]() Quote:
8" & 9" rear ends. They have always been quality bearings. Thanks, John Hope they have not moved off shore!! |
#18 | |
There was another post awhile back that listed some different interchange numbers:
https://www.fordbarn.com/forum/showp...7&postcount=14 Quote:
#19 |
![]() Model A Ford Transmission Roller Bearings |
#20 |
This site lists a ton of cross-references for A7118:
https://www.yoyopart.com/oem/1136319...ml#interchange And for A7121: http://www.kakapart.com/oem/partscro...r-j241256.html Maybe one of these is available. Here's a vendor selling a part that interchanges with A7118: https://wellertruck.com/inventory/pa...earing/bearing Here's someone on eBay selling 2 units that interchange with A7121: https://www.ebay.com/itm/BCA-Bower-J...-/233596345459 Last edited by alexiskai; 05-04-2021 at 10:41 PM. |
