Old 04-29-2021, 10:54 PM   #1
36Bill
36Bill's Avatar
Default 36 frame from a 60 motor
Is a frame from a 60hp car fit a normal motor?
It is a '37 and I want to put a '36
into it.
The best way to have a friend is to be a friend. Howdy Doody
36Bill is offline   Reply With Quote
Old 04-30-2021, 01:08 AM   #2
bbrocksr
Default Re: 36 frame from a 60 motor
into it.
Yes, take out the 60 front mount brackets and drop it in.
Bill
bbrocksr is offline   Reply With Quote
Old 04-30-2021, 01:59 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Like Bill says above, remove the wimpy V8-60 mounts that merely rivet to the "REGULAR" chassis front crossmembers. Once you remove the "60" brackets, you'll see the big holes for the 'big' engine mounts. DD
After removal, the biscuits and donut mounts for the 'big' engine just fall into place. Hope this helps! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-30-2021, 02:26 AM   #4
Desoto291Hemi
Good pics,,,,,,,makes sense ,,,,,,,that is a lot easier .
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 04-30-2021, 06:54 AM   #5
36Bill
36Bill's Avatar
Thanks guys
Old 04-30-2021, 08:02 AM   #6
1931 flamingo
1931 flamingo's Avatar
I believe the tranny's in a 60 are different as are the rear end ring and pinion.
Paul in CT
