Make sure the master cylinder pushrod is retracting completely. There should be approx. 1/4" pedal free movement before the pushrod contacts the master cylinder piston. If this is too tight the piston can't retract fully and you'll have a problem getting all the air out of the system. Also, if driven like this the brakes will drag when they heat up.
Good luck!
Ever stop to think and forget to start again? |
