hello
i am working on my rear brakes i need to get the e brake backing plate off to get to the brakes i have everting loose but the backing plate will not come off i do not want to bend it i do i get it loose with out doing damage to it this is on a 30 tudor thank you kevin |
Did you pull the emergency brake lever arm off?
hello Bob
yes i have everything off thanks |
Pull the grease shield
It will come off with a lot of twisting and turning, you probably think it won't but it will if you are holding your mouth right. I assume post number 3 is correct and that the backing plate and the E brake arm is all that is left to remove.
John Last edited by aermotor; 01-11-2021 at 08:07 AM. |
#6 | |
If the rear radius rod is bent it can make it difficult to remove.. pull the rear backing plate bolts.
If you are just removing the parking brake carrier, would not matter if the radius rods are in the way. The key would stop it from coming out or is just stuck. Try tapping side to side and see it will come lose.
I know the voices aren't real but damn they have some good ideas! ![]() |
Is the emergency brake toggle lever completely out? Originally, there were no zerk fittings on the lever housing and that sucker is often corroded fast.
hello all thanks for the replys
yes the e brake leaver and wedge are removed the e brake shoe is removed only thing left is to remove the e brake backing plate it will not budge |
How about posting a picture.
#13 |
You will find it easiest to drop the radius rod to get the backing plate off. Are you sure you have the 4 bolts out? I still say give it a tap side to side or try a pry bar to see if you can pop it free.
#14 | |
![]() Quote:
I'm not talking about the wedge. That's something else. I mean the housing for the toggle lever that activates the brake shoe and to which the rod is attached on the outside of the backing plate. |
#15 |
I think we need a picture with this one or a Les Andrews drawing with his names for parts, I am not sure everyone is talking about the same thing. Les Andrews Vol. 1 Mechanics Handbook page 1-43. There have been parts referred to that don't exist on the rear brakes.
John Last edited by aermotor; 01-13-2021 at 08:19 AM. |
#16 |
hello
i will get a photo tonight when i get home from work. i do not see a grease seal. i have all for bolts out of backing plat. i am getting ready to drop radius arm. the e brake leaver on back of the plate is removed as well as the wedge key thank you kevin Last edited by kwisor; 01-13-2021 at 06:12 PM. Reason: ADD PHOTO |
#17 |
hello
I tried to upload photos but it will not let me Kevin |
#18 |
#19 |
hello still can not get photos to upload it is called the e brake carrier i beleive
thank you |
#20 |
got it off there was to much grease on it did not see the grease baffle when i removed it i was able to get it off
thanks for the help kevin |
