Old 08-23-2020, 04:31 PM   #1
kenparker
kenparker's Avatar
Default Re: Crankshaft Counterbalance Weight
I have s set of counterweights from Berts. Bolt on then weld the ends. Set of 4. Each one weighs 3.1 lbs total weight of 12.4 lbs. They are the samee thickness as the counters on the crankshft - 5/8" thick.
also. crankshft turned 10/10 under weighs in at 24.8 with no counterweights. Second crankshaft also turned 10/10 under with the above weights added weighs in at 37 lbs.
kenparker is offline   Reply With Quote
Old 08-23-2020, 04:42 PM   #2
GerryAllen
What exactly are the counterbalance weights for. What effect would it have on my engine if it was not counter balanced.
Gerry Birch Bay WA.
GerryAllen is offline   Reply With Quote
