Jerry,
Be aware of the fact that not all power valves for the 94 are created equal. The one you want needs to have a completely flat surface where it mates up to the bottom of the carb. Newer valves have a "raised" machined surface that won't seal properly to our old carbs and will leak. If you're not sure what you have, post a pic or contact Sal (scicala) or CharlieNY here on the Barn. Mike |
All kinds of issues with modern power valves,from seal to fitment in the float well to opening values not correct.If you have an original or older power valve reuse it,or at the minimum save it
