Hi guys! There's probably a hundred strings on this topic but this is easier LOL.
What do you all recommend for 6V headlights? I want LED but I see a lot halogen kits on Amazon. Ideas? Sent from my SM-G973U using Tapatalk Last edited by msstring; 06-19-2020 at 07:37 PM. |
The halogen lamps are known to draw a lot more current than stock lamps. Not certain what charging system you have or how good it does its job.
Something to consider when making your decision.
#3 | |
![]() Quote:
Sent from my SM-G973U using Tapatalk |
This is a recent thread and quite thorough. I'd recommend checking that one out if you haven't already.
Mike https://www.fordbarn.com/forum/showt...dim+headlights |
You did not mention in your write up if you were referring to original reflector type lights or sealed beams.
The reflector '39 and earlier lights are a real pain to work with. I converted the headlights on my '36 to sealed beams in 1952 using a conversion for truck lights and '36 trk bezels. My lights don't have the '36 "bug eyed" look, but they work great. I got rid of the original switch on the bottom of the steering gears in favor of a dash mounted pull switch and a floor mounted dimmer. I also wired in a relay in lieu of direct wiring, the relay cut down voltage draw and made the 6v lights very bright. I have driven my car for thousands of miles over rural highways in all kinds of weather. I have a '39 conv that I converted over to halogen head lights, big mistake, the halogen bulbs don't work with the prism's in the lens, lots of un-directed light. I am in the process of converting the '39 back to bulbs, having reflectors nickle plated, securing new sockets and using Ron Francis 'Bright Bulbs.
Bill.... 36 5 win cpe |
