Old 06-09-2020, 08:11 AM   #1
Standing Elk
Default Thump thump thump
Wondering what the possibilities might be. At low speed 10-15 mph, with the clutch engaged I hear a thump thump thump coming from I think the rear of the car. It stops as soon as I put the clutch in. I feel no vibration at either slow or road speed. What would be the most logical cause? Thanks
Standing Elk is offline   Reply With Quote
Old 06-09-2020, 09:30 AM   #2
Marshall V. Daut
Default Re: Thump thump thump
Check your private messages in the top right corner of this webpage.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 06-09-2020, 09:51 AM   #3
Jacksonlll
Jacksonlll's Avatar
Loose wheel???
Loose axle nut??
Old 06-09-2020, 04:16 PM   #4
old31
Marshall
Marshal, instead of sending private messages could you send regular links so that we can all benefit from what needs to be said?
old31 is offline   Reply With Quote
Old 06-09-2020, 11:46 PM   #5
dumb person
dumb person's Avatar
Chipped gear tooth?
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 06-10-2020, 07:25 AM   #6
1931 flamingo
1931 flamingo's Avatar
Flat spot on tire?? Does noise go away after being driven for a while?? What make/brand of tires?? Age??
Paul in CT
Old 06-11-2020, 06:27 PM   #7
KGBnut
KGBnut's Avatar
I had a similar noise. It turned out to be a bad universal joint.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 06-13-2020, 02:44 PM   #8
Standing Elk
Thanks everyone. No loose wheels or axle nuts. Will have a look at the inside of the rear end to see if anything is as it should be. It is kinda weird though, Say you are going about 10 - 15 mph just kinda idling along and you can hear the thump but the instant you push the clutch in, the noise stops. I would think a u joint would still make noise. Also there is zero vibration at any speed. Thanks again
Old 06-15-2020, 09:59 AM   #9
chap52
chap52's Avatar
Just guessing here. Have yo lubricated the clutch through the top inspection hole recently? Could the throwout bearing or TO bearing hub not be evenly seating? There is a spring on the TOB Hub that may be weak??? Might be able to see something through the bell housing inspection/oiling hole.
Again, just a guess... Keep us posted. Chap
