Old 06-06-2020, 07:24 PM   #1
shew01
shew01's Avatar
Default Which Car-Like Vehicles Can Tow a Model A?
My wife is petite; so, she doesn稚 care to drive a full size pickup truck like a Ford F-150 (because it is difficult for her to see how to drive it).
Which car-like vehicles can tow a Model A using an open carrier like the ones available for rent at U-Haul?
https://www.uhaul.com/Trailers/Auto-...ort-Rental/AT/
What would be the combined weight of such a trailer and a Model A? My Honda Odyssey is rated for towing 3500 pounds, but I知 guessing a trailer loaded with a Model A will weigh more than that.
Old 06-06-2020, 07:34 PM   #2
shew01
shew01's Avatar
Originally Posted by shew01 View Post
It looks like the empty weight of the U-Haul trailer above is 2210 pounds, and I知 guessing the Model A is 2500 pounds or more; so, I値l need something other than my Honda Odyssey to tow the Model A.
Old 06-08-2020, 08:40 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Which Car-Like Vehicles Can Tow a Model A?
I know this is not part of the original question, but how often are we thinking about the need to tow the Model-A. Are we thinking once, -or possibly twice a year?
Another option to buying a specific vehicle is to rent a small moving truck when you rent a trailer, and just tow with that. If that is too utilitarian, another option is Enterprise rents ス and セ ton pick-ups and vans that could be used to tow the U-haul trailer if you are only trailering once or twice a year.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-06-2020, 07:37 PM   #4
40 Deluxe
Best check with U-Haul. They have a list of approved vehicles, and if yours is not on it they will refuse to rent a trailer to you!
Old 06-07-2020, 11:56 AM   #5
trulyvintage
trulyvintage's Avatar
Thumbs up Spot On
Exactly
The Uhaul insurance and your personal automobile policy can and will
deny coverage if you falsify either/or the tow vehicle used to pull
the rental trailer an/or the vehicle placed on the trailer.
Jim
trulyvintage is offline   Reply With Quote
Old 06-06-2020, 08:14 PM   #6
Curtis in MA
I rented a 2 wheel dolly from u-haul and towed with a Ford Explorer.
Curtis in MA is offline   Reply With Quote
Old 06-06-2020, 09:10 PM   #7
ronn
the odyssey would be fine with a regular car hauler. they generally weigh around 1500 ibs. The ones at uhaul are pretty beefed up. the avg A is just over 2000 IBS, so yes, possible to use the odyssey, Jeep, Ranger with v6 etc.
Old 06-06-2020, 11:02 PM   #8
Pete
I towed all over the country with these two combinations.
The 30 2 door has 4W disc brakes.
The other tow car was a Mustang Cobra.
The trailer had electric brakes.
Old 06-07-2020, 06:50 AM   #9
shew01
shew01's Avatar
Both of those tow combinations are quite unique. :-)
Old 06-07-2020, 06:00 AM   #10
Ray64
Ray64's Avatar
Ford Flex with towing package Plenty of power
Ray64 is offline   Reply With Quote
Old 06-07-2020, 12:53 PM   #11
trulyvintage
Lightbulb Not Recommended
" How much will a Ford Flex tow?
Flex Towing Capacity
The Flex can tow up to 4,500 pounds when properly equipped "
No way in hell would I pull a tandem axle car trailer with a car
on it with a Ford Flex or any similar vehicle.
Towing is not the issue - controlling what you are towing
under emergency conditions safely - is what matters.
Jim
Old 06-07-2020, 06:13 AM   #12
fuzes45
Son had Ford Explorer with independent rear axle, towing boat approx 3000# above
40 mph swayed all over road, if you have class 1 hitch on vehicle limited as what you can tow. Some rental agencies will not rent trailer if you have indenpendent suspension
in rear as some vehicles flipped over.
bob f
fuzes45 is offline   Reply With Quote
Old 06-08-2020, 08:30 AM   #13
BRENT in 10-uh-C
bob f
Bob, I have a Lincoln Aviator with the V8 (-which is the sister vehicle to the Explorer) and mine has a 7100 pound towing capacity with IRS. I have hauled Model-As inside an enclosed trailer traveling 75 mph without any handling issues whatsoever.
I also have had several Edges and an Explorer that we have towed an enclosed trailer with. The towing platform is the same between the two with the exception of the towing capacity of the Edge is less because of the rear spring capacity of the Edge due to no 3rd row seating. The tongue weight with the springs on an Edge is 350# whereas the Explorer tongue weight is 560#. With a load equalizing hitch and a sway bar, no issue towing whatsoever.
BRENT in 10-uh-C
Old 06-07-2020, 07:00 AM   #14
kenparker
kenparker's Avatar
A lot depends on the weight of the trailer. U Hauls, for exampleare about 2000 lbs. My flat bed wood deck 16 ft weighs only 1200 with dual axels and electric brakes. The other factor is weight of the vehicle to be trailered. Roadsters are in the neighvorhood of 2200 lbs and fordors are 2600 plus. ( dont now off hand exact numbers.)
My 31 coupe and trailer combined weigh n a 3460. My just finished Woody weighs in at 2865. Coupled with the 1200 fo the trailer, thats 4065 lbs. I will be towing woody to Texas Tour this Thursday with a Ford F150 short bed single cab with a little V-6 engine. Pulling over 4000 lbs at highway speeds ,60 plus mph, the engine does juz fine. BUT transmission wants to overheat. Solution is to not drive over 50 mph. Tranny stays cool, it just take an extra 15 minutes to get there. ken
Other solution is to install auxillary transmission cooler. I can install for about $200 but voids the factory warranty. Ford dealer can install and keep the warranty,but cost is over $700.
kenparker is offline   Reply With Quote
Old 06-07-2020, 07:52 AM   #15
denis4x4
denis4x4's Avatar
Too often, people under estimate the weight of a car/trailer combo and get into trouble or have mechanical issues. I suspect that the Honda will have a maximum tongue weight of 350 pounds and that will not work with a U-Haul. A tow dolly is about the only option I can see. For piece of mind, I would look into the cost of a U-Haul pick up and trailer.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 06-07-2020, 10:06 AM   #16
shew01
shew01's Avatar
I hadn稚 thought of renting a truck and trailer from U-Haul. Thanks for the idea.
Old 06-07-2020, 08:16 AM   #17
Chris in WNC
Chris in WNC's Avatar
friend of mine who trailers Buicks and Caddys cross-country a lot, wisely told me "use the biggest vehicle possible to tow".
I'd never consider anything smaller than a 1/2 ton truck. We had a 3/4 ton longbed Dodge diesel that was a killer tow vehicle.
As mentioned above, the U-haul approved vehicle list is a safe bet for this decision- it is a very conservative, lawyer-driven list.
Another friend was shopping for a tow vehicle and had a similar wife situation- she did not want a truck. He was considering a new Accura MDX and started quoting me the stats that the salesman gave him for reassurance. I reminded him that the salesman would be nowhere around if he found himself in a ditch in the rain someday......
Get you wife a car she likes (happy wife) and get yourself a good used 3/4 ton diesel truck for towing (happy life).
As also mentioned here, if your towing needs are infrequent, just rent a truck......j.m.h.o.
our next Model A has arrived.....
Last edited by Chris in WNC; 06-10-2020 at 07:52 AM. Reason: more information.....
Chris in WNC is offline   Reply With Quote
Old 06-07-2020, 08:34 AM   #18
chap52
chap52's Avatar
1952 Buick or Hudson... Don't use a two wheel dolly to tow an "A". Why put the rear end spinning for many miles when there are trailers available. Just my opinion! Chap
Old 06-07-2020, 08:56 AM   #19
Big hammer
How offen and how far would you be towing ! If only once or twice a year, rent a u-haul truck or van with their trailer. If you consider the price of tags insurance etc, it doesn't make scents to own a tow vehicle only to tow once or twice a year.
get a bigger hammer tap done
Old 06-07-2020, 10:11 AM   #20
shew01
shew01's Avatar
I壇 probably be towing once or twice a year. Dearborn, MI, is about a 1000 mile round trip for us.
I値l be replacing the Odyssey at some point, which is why I知 researching vehicles at the moment.
