Old 04-28-2020, 10:17 PM   #9
quickchange34
quickchange34's Avatar
Default Re: Oil slinger, crank snout, crank sleeve.
You need to keep the oil slinger . Once you install your crank pulley and the bolt and washer that holds it on it will hold the oil slinger in place tight against the crank gear.
quickchange34 is offline   Reply With Quote
