04-03-2020, 12:21 PM | #1 |
Reason to use distributor condenser hole plug.
No voltage to points. Looks like some insect had a good home for the winter.
04-03-2020, 02:36 PM | #2 |
Re: Reason to use distributor condenser hole plug.
Wow! Never seen anything like that~!
www.whidbeymodelaclub.com |
04-03-2020, 02:43 PM | #3 |
What's your upholstery look like??
Paul in CT |
04-03-2020, 03:39 PM | #4 |
Just a little detritus....
04-03-2020, 03:42 PM | #5 | |
04-03-2020, 05:28 PM | #6 |
04-03-2020, 05:53 PM | #7 |
Nice.
What is what looks like a tree limb slingshot on the back for? |
04-03-2020, 05:58 PM | #8 |
04-04-2020, 04:02 AM | #9 |
That would look much better with Model A wheels.
04-04-2020, 04:22 PM | #10 |
Distributor all cleaned and reinstalled. Engine runs but clutch is stuck. With engine off, it will shift into all gears. With engine running it grinds when trying to shift to any of the 4. Suggestions for the best way to get clutch to release would be appreciated.
04-04-2020, 05:45 PM | #11 |
Make sure you have some space in front of you, then start it in gear, get it moving, step on the clutch and then hit the brakes. That is how I have unstuck mine.
04-04-2020, 05:59 PM | #12 |
Will that work in reverse? It is in the garage at the top of the hill. I can only go backward for about 50 feet before being able to turn.
04-04-2020, 06:33 PM | #13 |
Please start a new thread with this stuck clutch problem in the title, to help others find the discussion in the future.
