Old 11-23-2013, 08:45 PM   #1
Ross/Kzoo
Ross/Kzoo's Avatar
Default Re: Speedster Kit
It does seem that with a few mods that you could make a press out of it.
Ross/Kzoo is offline   Reply With Quote
Old 11-27-2013, 02:30 AM   #2
aboneskd
I am building a speedster based on a Rootlieb kit. I hope to be installing the seat belts soon. Anybody who has built a Rootlieb have any suggestions or ideas. Thanx in advance.
aboneskd is offline   Reply With Quote
Old 12-13-2020, 09:59 AM   #3
Cadillac Bill
Cadillac Bill's Avatar
Originally Posted by aboneskd View Post
I am building a speedster based on a Rootlieb kit. I hope to be installing the seat belts soon. Anybody who has built a Rootlieb has any suggestions or ideas. Thanx in advance.
I bought 1927 (?) Model T speedster with a Rootlieb kit. I did not install it, but happy to share the work.
Cadillac Bill is offline   Reply With Quote
Old 12-13-2020, 07:04 PM   #4
Sparky
Sparky's Avatar
Wow, you went way back in time to pick up this thread😄. Anyways, your speedster looks very well done. I dig the headlights.
Sparky is offline   Reply With Quote
Old 11-27-2013, 07:16 AM   #5
QGolden
QGolden's Avatar
Check these out, I believe these are what I will be using.
http://wescoperformance.stores.yahoo.net/am4point.html
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 11-27-2013, 08:25 AM   #6
Sparky
Sparky's Avatar
Where would you attach the shoulder harness in a speedster? I don't think you should connect it to the floor.
I have a pair of universal mount lap belts in mine.
Old 11-27-2013, 04:41 PM   #7
BangerMatt
BangerMatt's Avatar
I have a pair of 4" military seatbelts in mine. Heavy duty and look vintage.
BangerMatt is offline   Reply With Quote
Old 11-27-2013, 06:49 PM   #8
Sparky
Sparky's Avatar
I acquired a couple of those but haven't come up with a good way to attach them to my wood floor. How did you do it?
Old 11-27-2013, 08:55 PM   #9
aboneskd
Thanx for the replies. I intend to use belts out of a old style bulldozer, nice and wide and adjustable to keep the buckle in the middle of your lap no matter what your 'size'.
Did you cut slots in the wooden base of the seat and bolts them thru the floor? The seats aren't mounted yet--trying to make a plan.
Old 11-30-2013, 11:31 PM   #10
Brian LI
Brian LI's Avatar
We (BangerMatt and I) used 1 1/2 x 1 1/2 x 1/4" steel angle bolted with 2 bolts per bracket through the floor of the speedster using VERY large fender washers on the bottom of the wood floow to spread the stress out over a larger area. This then gives a vertical plane to which you can bolt the belts.
I wouldn't advise attaching the belts to the frame. Our thoughts are that if an accident were to occur if the body separated from the frame the occupants would become trapped in between the frame and bodywork. Not a very nice scenario.
We left the bolts holding the belts to the steel angle so they can pivot on the bolts. All hardware is grade 8 with nylon locking nuts. Yeah, I know grade 8 bolts.... Other things will structurally fail before the bolts do.
By the way the wood floor of the speedster is 2 pieces of 3/4 inch plywood sandwiched together using screws and a liberal amount of glue. It is held onto the frame using 8 7/16 elevator bolts.
As someone else pointed out, tipping over is not the conceren, these speedsters have a fairly wide track and are very stable in turns. It's much more of a concern driving in an open vehicle and not wanting to get thrown out.
THAT would be a bad thing............
Oh, and the lean action in the turns is more to avoid mud than it is anything else.
Brian LI is offline   Reply With Quote
Old 11-27-2013, 08:55 PM   #11
QGolden
QGolden's Avatar
Install a piece of Channel or Angle crosswise between the frame rails under the seat?
I really like those Military Belts, era appropriate for sure! But I want a shoulder restraint on the drivers side. That steering wheel is not very forgiving.
Old 11-28-2013, 09:52 AM   #12
Farrell In Vancouver
Farrell In Vancouver's Avatar
I am curious about the discussion of seat belts in speedsters. Do any of you plan to add a roll over protection device to make sure the vehicle does not end up sitting on a well belted driver/passenger?
Farrell In Vancouver is offline   Reply With Quote
Old 11-28-2013, 02:41 PM   #13
QGolden
QGolden's Avatar
While a tip over is certainly possible, I am far more concerned with a quick swerve that topples an unsuspecting passenger over the side. Or a 30 mph bump after being run off the road. Statistically that is a more likely incident.
Old 12-01-2013, 08:51 AM   #14
QGolden
QGolden's Avatar
From my perspective, as this thread has migrated to seat belts, I was answering Farrell from the perspective of "puttin around". If I were to build a Speedster with the intention of the photos above, it would definitely have a roll bar. And a windshield for that female passenger in the last photo!
Old 12-01-2013, 11:31 PM   #15
Brian LI
Brian LI's Avatar
Brent - I completely agree with you that if we WERE racing these a roll bar would definitely be installed along with a 5 point harness. The pictures make it look MUCH faster than the actual speeds. The cars were traveling at about 40 mph and were on the track alone. This event provides track time that is strictly for photo ops and is controlled tightly. The reduced speeds and single vehicle on the track is the only reason passengers are allowed as well.
Besides these old things can't go that fast anyway.....right?
QGolden - These pics are from 2 years ago. There's an additional windshield there now!
Old 12-02-2013, 06:41 AM   #16
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Ok, I understand now. At least you are much safer and having fun!! Even though we were exhibition racing, those two words were defined separately in most of the driver's eyes!!
On half-mile tracks, WE were racing in excess of 60 mph in the straightaways. We were also wheel to wheel in most turns. Many in the group we raced with actually carried a passenger which was known as the riding mechanic. Towards the end, mant including me did not do that because the extra weight slowed us down. AARA has basically fizzled in my view but DAARA is still a very active group that races these. Back in our "glory days", we usually had 4 - 8 speedsters show up for a field. As the bottom 3 pictures will show, we weren't driving 40 mph and we were playing for photo ops.
1) A field in Marietta, OH lining up.
2) Me on the outside of Speedy Ed Johnson.
3) 4Banger Dan Price in his RAJO powered Model-T outside me in a Cyclone-headed Model-B powered Dodge.
4) Dreamwerks Engine builder James Rogers 'haulin the mail' in his speedster at Washington Courthouse.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-02-2013, 06:56 AM   #17
48fordnut
48fordnut's Avatar
Not that I will be racing mine,but those pics get the blood flowing.
This week will be doing some trading,ordering some of the things I need to get going. Will post some pics tomorrow,I hope, with the help of a friend.
I'm learning that the model A is not so simple.
Is there one particular book that I need?I am starting with a bare frame ,bare ft axle, and bare r/e.
Is there a site that shows schedule and racing events? As well as swap meets?
Great Pics, Brent.
48fordnut is offline   Reply With Quote
Old 12-02-2013, 07:15 AM   #18
BRENT in 10-uh-C
Great Pics, Brent.
Just as you found in your former drag racing career, there really is not any book that can singly tell you what you need to know. In the case of your speedster, you need to draw out your goals, then begin your build thinking through each step of the way. Be creative and make it your own.
As far as meets go, I think you just missed the Moutrie swap meet which would have been close to you. You were just at the Turkey so maybe you were able to gather some parts there. The one thing that you have as an obstacle is you are wanting to do this on a very limited budget. Most of the stuff (i.e.: bling or speed items) that you buy cost $$, ...so you need to be creative and find items that can be repurposed and with added detail.
BRENT in 10-uh-C
Old 12-02-2013, 07:51 AM   #19
48fordnut
48fordnut's Avatar
All good advice. I do have a plan of where I want to go, and the parts are starting to get together. While at daytona, I picked up some excellent 17'' wheels and tires, my brakes came in,and will be starting on the assy of the ft end parts. Hope to do some trading for a 28-9 grill and rad this week.
Next will be contacting a source about the eng/trans. The only speed parts I will be looking for will be a track style exhaust. I know the old saying of "speed cost money, how fast do you want to go''.
Getting it running is my main goal, then who knows.
What did you use to make your tank?
Old 12-02-2013, 08:19 AM   #20
Ross/Kzoo
Ross/Kzoo's Avatar
When I started my speedster project I thought that I had a realistic budget and I may have. As things progressed I modified my earlier plans and went the extra step on almost every step of the way. Things like 16" powder coated wheels instead of the stock 21's and that meant new rubber all around. Sometimes I'd mock up 2,3 or 4 different assemblies before I picked the one that suited me best. It's things like that made it go to double my original budget. I'm glad that I went with choices that I made but it was more costly.
