Old 06-27-2019, 09:04 AM   #11
30 Closed Cab PU
Default Re: Locating dimple on timing gear
Originally Posted by donald1950 View Post
i just spent about 2 hours turning the motor over very slowly with the fan belt and watching the rotor approach #1 position and i finally hit it and then use the fan belt to rock it back an forth to verify. it sure dont move much.......
I believe one or two of the venders sell a timing pin that is spring loaded so you do not have to hold the pin while turning the motor - maybe that would help.
Do not remember why, at one time was told not to use the fan belt to turn the motor, maybe hard on the water pump and generator bearings?
Also maybe something about the belt being tensioned to tight if able to turn the motor with the fan belt?
Interested in what other say about this.
