Old 05-04-2019, 02:55 PM   #101
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Air filter for Model A
And the groove machined into the outside of the venturi routes the vent to the 3/16" hole to the carb throat. The "channel" from the float bowl does not go into the venturi, it goes around the outside of the venturi to the throat of the carb. I don't know how to better explain it.
Old 05-04-2019, 03:38 PM   #102
Werner
Werner's Avatar
Blockhead, I try it again. Please see picture. Sorry for my bad understanding.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-05-2019, 03:40 PM   #103
Werner
Werner's Avatar
I would like to ask if somebody can explain something to me about the milling between the float chamber and the venturi hole.
Werner
Citroen 11 CV, 1947
Old 05-05-2019, 06:22 PM   #104
Synchro909
Synchro909's Avatar
I didn't get too worked up about doing this. I don't have a milling machine and there is no need for great precision. I used a die grinder there asnd on the lip under the venturi.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 05-05-2019, 06:27 PM   #105
Synchro909
Synchro909's Avatar
Originally Posted by katy View Post
Would it work with one of these?
Katy, just back from yet another rally. Sorry for the delay replying.
I haven't seen either one of those air filters or one of those oil filter mounts on a car, let alone both at once. Your suggestion might work.
Has anybody tried it???
Old 05-07-2019, 02:55 PM   #106
Werner
Werner's Avatar
Hallo again,
I changed the Zenith-2 again on air-ballance today. From the float chamber directly above the choke flap shaft's front. Instead of brass, I used this time 1/5 inch copper tube, which can bend broken fracture-free and therefore build in one piece from hole to hole.
Werner
Citroen 11 CV, 1947
Old 05-08-2019, 11:19 AM   #107
Werner
Werner's Avatar
Now I have to ask again: I have just noticed today that there is in the upper carburetor housing an additional hole for venting. Above the hole in the under housing. (I do not understand the reason because 1 is enough.)
I think now that I have to close this hole too?
Werner
Citroen 11 CV, 1947
Old 05-08-2019, 11:34 AM   #108
Werner
Werner's Avatar
Addition:
Here in the book picture the channel is drawn. Unfortunately, he is not mentioned in the text.
Werner
Citroen 11 CV, 1947
Old 05-08-2019, 06:14 PM   #109
duke36
Originally Posted by darrylkmc View Post
The last thing that I would want is Gasoline drenched ABS plastic that close to my exhaust.
Darryl in Fairbanks
The ebay seller says it's 2 copper elbows.
Old 05-08-2019, 07:23 PM   #110
Synchro909
Synchro909's Avatar
That is not an original hole. I'd seal it too as you suggest.
Old 05-08-2019, 09:49 PM   #111
Tom Wesenberg
Tom Wesenberg's Avatar
If you modify the carb for an internal vent to the front of the choke, to use an air filter, then you also need to block off the original external vent.
Old 05-09-2019, 03:15 AM   #112
Y-Blockhead
Why do you need to run the vent all the way to in front of the choke? My air balanced Zenith is vented to the carb throat just before the venturi. See photo in post #98.
Old 05-09-2019, 07:56 AM   #113
Synchro909
Synchro909's Avatar
So long as the vent is between the air filter and the venturi, it doesn't matter. The pressure will be the same anywhere in that piece of the intake.
Old 05-09-2019, 08:26 AM   #114
Ed in Maine
I think Charlie summed it up perfectly. Why not have your Model A run as Henry wanted it to during your life time! You don't need the air filter. Just my take, Ed
Old 05-09-2019, 08:51 AM   #115
SkimmerBob
SkimmerBob's Avatar
Originally Posted by burner31 View Post
Hold filter firmly in hand...throw as far as possible...drive car
That’s funny!
SkimmerBob is offline   Reply With Quote
Old 05-09-2019, 09:48 AM   #116
Werner
Werner's Avatar
Error. With the sealed hole the engine was not adjustable and too rich. The ventilation hole in the upper housing is necessary to get air into the channel for the idle needle!
Blockhead: Meanwhile, I have the hose line as shown by you in the area of ​​the choke flap. Thank you!
Synchro: Your comment is correct. Nevertheless I have now the tube pipe layed to a short distance before the choke flap achsle to get a shorter pipe.
Thanks to the helpers! Now my engine sucks in dust-free air and the carburetor does not mix too rich.
Werner
Citroen 11 CV, 1947
Old 05-09-2019, 09:59 AM   #117
Y-Blockhead
Yes, you and I know that. I was asking Werner.
Please tell me why my air cleaner gets dirty. And I run engine pans.
