Old 02-04-2019, 02:22 PM   #1
Bob NH
Bob NH's Avatar
Default Question ?
What is the oil pressure gauge supposed to be for a 1946 pickup, 50 or 80 LB ?
Bob NH is offline   Reply With Quote
Old 02-04-2019, 02:45 PM   #2
Bob NH
Bob NH's Avatar
Default Re: Question ?
OOPS, I meant the sender unit on the block !
Old 02-04-2019, 03:27 PM   #3
bobwellsnoveltyshop
The sender should be the 80 lb. the gauge also should have the 0-30-80 on the face.
BILL WELLS
bobwellsnoveltyshop is offline   Reply With Quote
Old 02-04-2019, 03:53 PM   #4
Bob NH
Bob NH's Avatar
That's what I thought. I just bought one that is supposed to be 80 LB and I am only seeing a KS stamp with a 5 under it which makes me think it may be 50 LB ?
Old 02-04-2019, 04:54 PM   #5
ford38v8
ford38v8's Avatar
If you bought it from a dealer, no way would it be an original 50#. It might be an offshore repop. From a swap meet, you may have gotten lucky and found gold.
Alan
Old 02-04-2019, 06:31 PM   #6
rotorwrench
rotorwrench's Avatar
The early ones were generally not marked until the change to the 80 psi. After that, they were all marked in order to tell them apart. If it has KS on it then it should be an original King Seeley. They have not reproduced these for many years so the later repo stuff will not have KS on it. You can find NOS and good used 80 psi units on flea-pay but there is always a bit of risk there. Barnfind08 (Southside Obsolete) may have some NOS ones.
I'd say there is a pretty good chance that the one in question is a 50 psi unit. All the 80 psi units were marked as such.
Old 02-04-2019, 08:38 PM   #7
Kube
Kube's Avatar
I've got a NOS 80# unit on ebay at this very moment.
Old 02-05-2019, 07:21 AM   #8
Bob NH
Bob NH's Avatar
Kube or anyone else, If I take a picture of this sender and its markings and send it to you, can you ID it positively for me ?
Old 02-05-2019, 10:21 AM   #9
Kube
Kube's Avatar
Of course, send away.
Check my auction, eBay #113606594702. That will show you clearly what you are looking for.
Old 02-05-2019, 04:29 PM   #10
V12Bill
V12Bill's Avatar
Your 1946 truck should be a 59A engine and as such, should have a 50# oil pump in it. The 8BA engine that came out for the 1948 F1 and the later passenger car had an 80 # oil pump and thus needed the 80# sending unit. As stated above, the 50 # units were not marked until the 80# units came out because the only unit available was a 50# unit.
V12Bill is offline   Reply With Quote
Old 02-06-2019, 11:00 AM   #11
Bob NH
Bob NH's Avatar
0-30-80 0n dash gauge
