Old 11-21-2018, 08:41 PM   #12
Smog Tech
Smog Tech's Avatar
Default Re: pressurized radiator work around
Not all pressure caps will work with an overflow tank. You need a pressure cap with two rubber gaskets, one to seal the pressure and one to seal the cap. You can remove the rubber gasket from the pressure seal and run "O" pressure.
Smog Tech is offline   Reply With Quote
