So what is the trick to get the cowl lights apart 30 coupe? Time to replace the bulbs
There is either a screw on the bottom of tge lens ring or a screw on the back of the light body. once the screw is removed, a small screwdriver can be used to pry slightly on the ring and the cowl light will separate.
I went with the LED replacement bulbs, very nice, very bright.
Just had to widen the hole in the reflector a few thousands with a round file, easy, and they work great.
