Old 06-04-2018, 07:41 AM   #1
fords
Default Engine no serial number
I acquired a model A engine and transmission at know charge. The serial number has been removed - seems it was machines off. What does this do to the value?
I want to rebuild for the heck of it and if I wanted to sell - would no serial number be an issue?
Thanks guys
fords is offline   Reply With Quote
Old 06-04-2018, 07:47 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Engine no serial number
having the serial number on the block is nice to know what car/year it came out of but not necessary for anything. most model A's dont have their original engines anyways and restorers like to restamp the frame number on the new block anyways.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-04-2018, 08:21 AM   #3
Josh Randall
Replacement blocks were not stamped according to this.
http://www.fordgarage.com/pages/diamondblock.htm
Josh Randall is offline   Reply With Quote
Old 06-04-2018, 10:17 AM   #4
burner31
burner31's Avatar
Where the diamond would be I have what appears to be an "X"
Would that mean anything?
Keith
Shawnee OK
'31 SW 160-B
Old 06-04-2018, 09:02 PM   #5
fords
Thanks guys appreciate the feed back. Will go and look closer to the block and see what other cast infonthere might. Also it was at NO charge. (Not Know)
Old 06-05-2018, 01:51 PM   #6
Chris Haynes
Chris Haynes's Avatar
The Diamond is cast as part of the block. It is raised. It is not stamped as your "X" is.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-05-2018, 02:26 PM   #7
burner31
burner31's Avatar
I understand all thst.
But what is the X?
I like to believe it means "extra fine motor", seeing how the motor runs great
Keith
Shawnee OK
'31 SW 160-B
Old 06-06-2018, 07:52 AM   #8
garyjohn
I am running a factory replacement motor built in 1934 and has NO diamond on it. The diamond blocks are industrial motors.
garyjohn is offline   Reply With Quote
