Not really an issue, just curious. I have a fresh rebuild with a 5.5 head initially torqued to 60 lbs. Ran it once and got some good heat through it, cooled off completely and went to re torque the nuts. Unlike a dozen times before on various engines, the nuts held they're torque. I pulled up to 75 pounds thinking they would "TINK" and then turn at a lower value, but they didn't budge, so I let off. I'm fine with it, I guess, just never experienced this before. Thoughts from the experts?
Don't worry about it. Run it 50 miles and check them again.
Im at the same stage but on a 59 V8 . I've had motors hold but this time after first heat cycle I felt some of the bolts move. That right I used 8ba bolts on a 59 ,no studs . First try ...
"I can't cry as long as I know the Lord has risen " |
So I'm confused. What is your final torque?
It's called "stiction", that initial resistance to turning. Always back off the nut about a quarter turn or so first, then torque to specs.
What head gasket did you use?
Did you install the head gasket? I will post a guess after you answer this.
http://www.model-a-ford-4bangers.com/ |
One, I always thought never to back off the nut.
Two, 75 lbs is too much. It should be 55 lbs. |
It is a Rich Fallucca engine. I don't know what kind of head gasket he used. I am inclined to leave it alone as some have suggested. I did not tighten them to 75, because they didn't move. They are still at the initial 60 lbs.
If the nuts are stuck on the threads you don't really know what the torque is.
I use ARP Ultra-Torque Assembly Lube on head nuts. Nuts don't stick to the threads.
I worried about the nuts loosening, but that a has not happened yet. I torque Model A heads to 55 lbs. |
#13 |
The only time I found a head gasket (copper) that didn't compress after a heat cycle is when an old gasket was re-used. They don't compress because it is compressed as much as possible. Gaskets can be re-used BUT, not on a new customer engine without the customers knowledge.
