#21 |
Throw it my way !! If the pits do not go all the way across the surface it won't give any trouble. Been running one over 20 years like that . An old Ford mechanic gave me that advice.
#22 |
#23 |
Right-on Tubman. I just finished doing mine, didn't pull complete rearend. Replaced right axle, all bearings and seals, and was 79 yrs. old. Some people are afraid to tackle any kind of job that takes a little effort. I like to have wore the creeper wheels off, going in and out from under the car, but had a blast doing it myself. Al
#24 |
The housings must be machined to receive a hardened sleeve. It does require a lathe with a big swing to accomodate the housing, and exact machining to accept the sleeves as a press fit. Choose a very good shop, and be sure the sleeves are actually case hardened. At one time the market was selling soft sleeves which defeated the purpose pf the repair.
#25 |
#26 |
#27 |
Another way to have it done. If you know a crank shaft grinder.
#28 |
i was told years ago they are so hard you need to grind them like terry shows. seems mart had no problem in the lathe, i have some from john at columbia to install, i'll try my lathe first
#29 |
What do you guys think about the HRW banjo kit using the Ford 9" axles in a basically stock banjo rear. $1100 tho. Worth it?
Phil |
#30 |
I have one in my avatar roadster that Wayne in Idaho did the work on back in maybe 1998. I ended up with a nice banjo looking rear end and axle housings and stock spring with 9" axles, bearings and brakes. Have over 6k trouble free miles on it.
I believe HRW is the same business and Wayne retired and sold to his kids or some other family relation and came up with that name. I did this modification because I am putting more then stock power to the rear and I didn't want to wonder about the axles even though I have sets of NOS axles for my cars. I have stock axles in the cars with stock engines. |
#31 |
I did the same setup (well similar) using the old 50s home brew method.
#32 |
Why not just take the axle housing off and have the old race machined and install a new race? Seems like a lot less expense. Also as others have said if the pitting doesn't go all the way across the race why mess with it?
#33 | |
![]() Quote:
#34 |
Phillip Swanson
If your concern is the groove & pits on the axle made by the inner axle seal, Dick Spadaro had a fix for the problem. After removing the axle housing insert a new seal on top of the old seal. Yes leave the old seal in place add a new seal against the existing seal, this allows the new seal to ride on fresh spot on the axle. |
#35 |
#36 |
This is HRW current kit. I used it for the safety factor plus less maintenance.
John |
#37 |
i had the Hot Rod Works semi floater axels on my 1941 ford Pick Up and it was a great conversion.... a bit expensive but well worth the cost in reliability. original conversion had the A/B motor and when i sold it 12 years later it had a hot 350 chev and a T5..... nothing ever caused problems. very high quality work done by them...
#38 | ||
![]() Quote:
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-19-2018 at 03:55 PM. Reason: Added some winks because someone thought I was serious :D |
#39 |
I would think it would cost more to narrow a 9" and then deal with switching to an open driveline then it would cost to use HRW parts and retain torque tube and radius rods. I bet most folks couldn't tell the difference from stock unless they were real keen on identifying backing plates.
If philipswanson's car is stock, just fixing the original housings is probably the cheapest way to go. |
#40 |
I don't understand this comment at all. Putting a later open rear axle under an early car is not a simple or cheap undertaking and totally changes the appearance. An axle swap is no where near as involved and looks original.
