Old 10-16-2017, 10:34 AM   #1
TMB
Default Oil Change Surprise
'29 Murray Town Sedan. After changing my oil I noticed some small pieces in the bottom of the bucket that look like they could be broken off teeth fragments of some type of gear. Am suspecting it is my fiber timing gear (have not verified yet) but wondering if this could be something worse? Car runs fine. Areas for me to inspect?
TMB is offline   Reply With Quote
Old 10-16-2017, 10:45 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: Oil Change Surprise
well are they metal or fiber magnet should answer that. if fiber its the timing gear. if its metal i highly doubt the crank gear would shear unless it was severely pitted. Any other metal gear the car wouldnt run right.
you could pull the small side timing cover off and slowly rotate the crank and inspect the timing gear for missing teeth.
if it looks OK it may be old teeth particles that have been in the pan a long time.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-16-2017, 11:42 AM   #3
Will N
Will N's Avatar
Could be bits of the Babbitt thrust bearing that have broken off.
Will N is offline   Reply With Quote
Old 10-16-2017, 01:17 PM   #4
hardtimes
hardtimes's Avatar
IF you cam gear is still of fiber variety, and bits are of fiber...pull timing cover..voila !
If this cam gear must be replaced, good news is that you can improve your engine overall by replacing fiber gear with McEachern alum or bronze cam gear.
Now, possible bad news is....you most likely have these bits in places where you would not want them..i.e.- oil pump/bearings/passages, etc...
Best to get that cover off first to see how much fiber is loose in your engine.
Old 10-16-2017, 02:14 PM   #5
richsfords
richsfords's Avatar
I changed my fiber gear during a overhaul, because of missing teeth, several oil changes ago and still (ever diminishing) getting few bits of fiber gear in the oil during the change. Also put in a magnetic drain plug to monitor the engine'
good luck
Richard in New Bern.
When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford
richsfords is offline   Reply With Quote
Old 10-23-2017, 06:47 AM   #6
TMB
Thanks Barn. On to investigation phase.
Old 10-23-2017, 08:03 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
Things I have found in the oil drained from the crankcases of Model A's:
> Pieces of cotter pins from connecting rods;
> Bits of metal from oil tray troughs;
> Pieces of rear main bearing thrust face babbitt;
> Chunks of silicone gasket material;
> Oil drain pipe from rear main bearing cap;
> Teeth from camshaft timing gear;
> Clothes line rope used to tie up the oil pump;
> Sludge from use of non-detergent oil.
Bob Bidonde
Old 10-23-2017, 03:55 PM   #8
hardtimes
hardtimes's Avatar
To add to your list:
The tops of two alum pistons !
3 to 4 inches of VERY thick 'muck' containing all manner of debris !
Old 10-23-2017, 04:10 PM   #9
msmaron
msmaron's Avatar
If you need a McEachern Bronze i have a NEW One for sale
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 10-23-2017, 10:13 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
But a thick layer of sludge helps to muffle engine noises.
