Old 09-13-2017, 12:44 PM   #1
wingski
wingski's Avatar
Default trouble shooting
Hello again. I took the ’29 cabriolet for my first drive with my wife and dog Tuesday evening. It started easily and ran fairly decently for the first few minutes, but started missing and trying to die pretty quickly. The gas valve was turned on, the spark was advanced, the throttle lever was all the way back up, and the choke was in and turned out about 1/2 a turn. The only way I was able to get back home was by pulling the choke out and pushing it back in. That allowed me enough power to go forward until I had to do it again. There are twin Tillotson carbs and a newer distributor on the car, and I don’t know what has been done to the engine.
My question is: Where do I start to find out what’s wrong? I’m going to pull the timing gear cover and check the timing just to be sure. Then, I’m going to check the distributor and points, but I feel that a lot of the problem is the carbs. I have the original intake manifold and Zenith carb, but I hate to take off that Vortex manifold and carbs because I don’t have the original fuel line for the Zenith. The gas was fresh and good, and both screens in the gas tank and sediment bowl are clean and clear. I have two inline filters going to the carbs and they’re clean, so this is not a gas problem. I wish I knew what head and what bore the engine is, but I don’t.
Thanks again for all the help you guys have given me. Mike
wingski is offline   Reply With Quote
Old 09-13-2017, 12:57 PM   #2
barnstuf
Default Re: trouble shooting
Some in line fuel filters do not work with gravity feed as they require fuel pump pressure. Are you on gravity feed?
barnstuf is offline   Reply With Quote
Old 09-13-2017, 12:58 PM   #3
mike657894
mike657894's Avatar
check compression and generator and battery connections. a blown head gasket will let you run for ten minutes then 2 cyl will stop sparking due to coolant build up. if you have a loose gen connection and your battery loses connection your car will back fire and drive with nearly no power. it could be something else but I would check those two first.
mike657894 is offline   Reply With Quote
Old 09-13-2017, 02:25 PM   #4
wingski
wingski's Avatar
Yes, it is gravity feed, and if all else fails I'll bypass the inline filters. Thanks.
Old 09-13-2017, 02:43 PM   #5
wingski
wingski's Avatar
All the head bolts were about 40 foot lbs. when I got it. I tightened them to 50 lbs, but there is a little bit of seepage from #8 head bolt. The previous owner was either weak or had no idea what he was doing, and that scares the crap out of me. I didn’t check to see if I had liquid coming out the exhaust when I fired it up. I will. Does it make a difference that the radiator has Evans waterless engine coolant in it because it does?
Old 09-13-2017, 02:45 PM   #6
Sunnybrook Farm
Sunnybrook Farm's Avatar
It sounds fuel related so I wouldn't mess with a lot of other stuff other than to check the point gap. Can you see any dirt in the sediment bowl if you have one or fuel filter if plastic. Maybe a photo of your system will help in trouble shooting.
Sunnybrook Farm is offline   Reply With Quote
Old 09-13-2017, 03:05 PM   #7
George Miller
George Miller's Avatar
Sorry but you have a gas problem. Probably a flow problem OR Vapor lock.
George Miller is offline   Reply With Quote
Old 09-13-2017, 03:10 PM   #8
abachman3
abachman3's Avatar
This sounds to me like a fuel starvation issue. The inline filter(s) may not be flowing enough fuel to feed both carbs. When you said that pulling up on the choke lever, it ran better, that seems to solidify, to me, a lack of fuel.
abachman3 is offline   Reply With Quote
Old 09-13-2017, 03:11 PM   #9
marc hildebrant
marc hildebrant's Avatar
Some of the older gas caps did not have good venting. Try removing the gas cap and see if it runs O.K. If so, then you need a new gas cap.
Marc
marc hildebrant is offline   Reply With Quote
Old 09-13-2017, 03:24 PM   #10
Bill G
Bill G's Avatar
Wingski:
It never fails. You do all that work and load up the wife and dog, and then it happens. I did a bunch of work and took my wife out for a drive one night and my generator was not genning, and by the time we got home, I almost had to hold a match up to the lights to see if they were on. On top of that, something else went haywire too. So much for impressing my wife with all the work. All fixed now, but geez.
Old 09-13-2017, 03:28 PM   #11
NCRebel
NCRebel's Avatar
I agree that vapor lock may be the issue. Fuel filters clogged are also an easy thing to check as well as a tight connection along the exhaust system from manifold gasket to the tail pipe opening.
NCRebel is offline   Reply With Quote
Old 09-13-2017, 03:48 PM   #12
frank mcdaniels
frank mcdaniels's Avatar
Fuel lines are cheap. I'd put the original manifold and single carb back on. Setting one carb and trouble shooting it would be way easier than two.
frank mcdaniels is offline   Reply With Quote
Old 09-13-2017, 04:19 PM   #13
wingski
wingski's Avatar
Originally Posted by Magicbox51 View Post
Wingski:
Bill, the thing that blows my mind is she said, "I really enjoyed that drive." when we got home. Boy, have I got a winner or not.
Old 09-13-2017, 04:24 PM   #14
wingski
wingski's Avatar
Hey Rebel, now that is what a parade car should look like. If I saw you go by, I'd have to follow you so I could shake your hand and congratulate you.
Old 09-13-2017, 04:26 PM   #15
wingski
wingski's Avatar
Marc, that's the first thing I checked, and it is venting properly. Thanks, Mike.
Old 09-13-2017, 04:29 PM   #16
wingski
wingski's Avatar
Thanks, Frank, but I really would like to see what these Tillotson's do compared to the Zenith.
Old 09-13-2017, 04:32 PM   #17
wingski
wingski's Avatar
Keep those comments coming, guys. Right now, I'm removing two scratches in my windshield so the A doesn't have to run.
Old 09-13-2017, 05:46 PM   #18
PC/SR
Retorque the manifold; besure it is properly installed, gaskets to block and carb, etc.
PC/SR is offline   Reply With Quote
Old 09-13-2017, 06:56 PM   #19
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
With so much stuff ADDED/MODIFIED/ETC, how in the world could you even begin to DIAGNOSE the problems?????
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-13-2017, 07:11 PM   #20
SteveB31
SteveB31's Avatar
Very simple problem. If you had to choke it to run, then you have a lack of fuel. Either to the carburetors, or thru the carburetors. Don't touch the electrical system. Pulling the choke starves it for air, and it runs because it is starved for fuel.
SteveB31 is offline   Reply With Quote
