Old 09-05-2017, 03:56 PM   #1
flssaturday
Default Twin turbo flathead
Doing a twin turbo setup an a 49 merc 8cm. Any advice or idea's on what internals ate needed to handle boost.
Piston bore,intake valve size,exhaust valve size,gppd came . Ect.thanks
Sent from my SM-N910P using Tapatalk
flssaturday is offline   Reply With Quote
Old 09-05-2017, 04:28 PM   #2
woodypecker
woodypecker's Avatar
Default Re: Twin turbo flathead
forged pistons, low timing, low compression, very high octane, and good luck.
woodypecker is offline   Reply With Quote
Old 09-05-2017, 05:04 PM   #3
flssaturday
Thanks will post thread as build goes on.
Old 09-05-2017, 05:13 PM   #4
40 Deluxe
Where did you find the small turbos you need?
Old 09-05-2017, 05:15 PM   #5
flssaturday
I found a kit ebay.
Old 09-05-2017, 05:30 PM   #6
JSeery
JSeery's Avatar
There is a lot of information out there on supercharging flatheads. I would think a lot of it would be similar.
Old 09-05-2017, 06:43 PM   #7
rotorwrench
rotorwrench's Avatar
Twin turbos can equal twice the headaches. Makes for a very busy engine compartment and exhaust system. I had enough troubles with only one on the old 47G3 series helicopters. When it is all working right it will make the engine breath but it takes a while to get over the turbo lag. The little ones spool up faster but they don't pump as much either. It will still have some lag. Would be Ok on the long dry lakes though. For street, it's hard to beat the roots type supercharger. Be prepared to spend a LOT.
Old 09-05-2017, 06:48 PM   #8
Bruce_MO
You might want to contact Jack Stirnemann in St. Louis. He built a twin turbo flathead a few years ago. He and his brother Harry can do amazing stuff with flatheads.
Bruce_MO is offline   Reply With Quote
Old 09-05-2017, 07:48 PM   #9
flssaturday
Thanks will try him
Old 09-05-2017, 07:55 PM   #10
paul2748
paul2748's Avatar
Maybe a girdle for the bottom end?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-05-2017, 08:24 PM   #11
flatheadmurre
flatheadmurre's Avatar
Depending on what power you aim for steel main caps and if they are oilcooled perhaps a higher flow oilpump and an oilcooler.
Old 09-06-2017, 08:02 PM   #12
1930 turbo
1930 turbo's Avatar
Hit the search link at the top of the page and type in twin turbos. I posted my homemade setup setup back in April. You don,t need larger valves, stock compression is low enough, and we usually run premium gas. It will run o.k. on regular if you don,t run it hard. I limit the boost to 5lbs. You will like the way turbos make that Merc engine run! Good Luck!
1930 turbo is offline   Reply With Quote
Old 09-06-2017, 09:08 PM   #13
flssaturday
Thanks!! Will look.
Old 09-06-2017, 10:19 PM   #14
VeryTangled
VeryTangled's Avatar
Have fun with some photos...
https://www.google.com/search?rlz=1C...h=588&dpr=1.56
-Jeff H
