Old 08-27-2017, 06:45 AM   #3
Terry,OH
Terry,OH's Avatar
Default Re: 37 Headlight Wiring
Maybe: Your diagram does not appear correct. From the rear of the switch you will see two groups of three terminals that all three of the terminals are connected together or electrically common to each other. The third group of three each terminal is independent from the others in this group. Notice the switch on the wiring diagram the independent group does not have lines between the circular terminals. The independent terminals are where you place the park BY, low BR, and high BG wires. To make things bad the wiring diagram is incorrect, the BR and BG wires should be swapped. this will determine which headlight will light first when turning CCW low or high beam. Below is the wiring for the light switch for 35-36 it has more detail including the square cut out location.
Terry,OH is online now   Reply With Quote
