08-13-2017, 11:01 AM | #41 | |
Re: Detergent oil
08-13-2017, 12:16 PM | #42 |
Re: Detergent oil
And I wasn't disagreeing with you, Sir. And that is why I still advocate using an Air Filter and an Oil Filter. Yes, some of the smaller "particulate" won't be filtered, but larger particles will... before they get to the bearings.
08-13-2017, 01:25 PM | #43 | |
Re: Detergent oil
08-13-2017, 01:27 PM | #44 |
Re: Detergent oil
Bit of Financial Advice:
If any Model A guy ever looks on the NY Stock Exchange and sees a new company listing. e.g., "Model A OiL - Exclusively Designed for Model A's" Pass it up ..... nobody on this Model A Forum will buy this crap. Last edited by H. L. Chauvin; 08-13-2017 at 01:28 PM. Reason: typo |
08-13-2017, 02:09 PM | #45 | |
Re: Detergent oil
You have an interesting theory on dilution effects 40 Deluxe..No doubt about the gasoline evaporation effect,but the unburnt fuel that does get passed the rings carries soot and is very acidic.In my opinion it causes breakdown of the oil and contributes to bearing failure.I still see the advantages of the CD oils as opposed to the SN oils with the A engine..the CD oils are more tolerant of gasoline washing past the rings due to its superior detergent and soot entrainment qualities. |
08-13-2017, 11:30 PM | #46 |
Re: Detergent oil
08-13-2017, 11:39 PM | #47 |
Re: Detergent oil
08-14-2017, 06:36 AM | #48 |
Re: Detergent oil
Here is a question..
Who knows of any recent engine that has had issues with dirt causing pre-mature wear and failure? Who knows of any recent engine that has failed because the oil went bad? So far I have never heard of any, modern or old normal engines that may have failed because the oil failed or too much dirt caused it to fail. Of course, I want to hear some science to back up the diagnosis, not 'it must have been the oil'. All the A engines that I have seen failed have been because something was built wrong or it was just plum wore out from tens of thousands of miles. You all just worry too much about stuff that makes no sense. The car does not need filters. It does not need fancy nothing. It just needs loving care in the building and it you can run it regularly and it is ready to run the next day, for decades!! You do not need to baby it either. If it is balanced right the engine will be happy run. How do I know this? I have listen carefully to the guys who have run for tens of thousands of miles. They have tried everything and the common thread with these guys is they know Fords original specs and the build to them. They do not bother with all the speed stuff (they all have tried it), some have counter balanced cranks and some have overdrives. They all think nothing of running 55 MPH all day long. Quit worrying about he oil. Use something with additives, do not change it too often, go drive. |
08-14-2017, 07:54 AM | #49 |
Re: Detergent oil
Kevin in NJ
Very well said!!! |
08-14-2017, 08:32 AM | #50 |
Re: Detergent oil
No argument over the simplicity and robust characteristics of the car in stock form,and I agree spending thousands of dollars chasing speed from an L head 4 cylinder 200 cubic inch engine is at best a lesson on disappointment. But I do see modern oil as a way of improving the chances of what you have lasting longer,oil and air filtration are proven to extend engine life.
I see the full flow as the answer as well Y Block...just wonder if flow and pressure should be improved before adding the restriction of a filter. |
08-14-2017, 09:12 AM | #51 |
Re: Detergent oil
Model A oil appears to be like personal liquor choices where some like white wine; some red; some dark beer; some light beer; some scotch, some bourbon; some gin; some vodka; some no alcohol.
Next comes the mix & additives; One shot, two shots plus MMO, stabilizers, and other additives. Model A owners will always have different mindsets and different choices where one (1) oil will never corner the market no matter who prepares the marketing. A bar that sells only gin will also go broke in a hurry. Last edited by H. L. Chauvin; 08-14-2017 at 09:13 AM. Reason: typo |
08-14-2017, 09:24 AM | #52 | |
Re: Detergent oil
08-14-2017, 11:14 AM | #53 | |
Re: Detergent oil
We sure have traveled far from the original question... |
08-14-2017, 11:47 AM | #54 | |
Re: Detergent oil
08-14-2017, 12:41 PM | #55 |
Re: Detergent oil
Did anyone notice that of all the different oils discussed on Model A Forums over the past 20 years, nobody ever mentioned Croton Oil, a Detergent Oil that was still being sold in drug stores during Model A days.
I used to hear the old people, (born in the late 1800's), talk about a person in our neighborhood who placed one drop of Croton Oil in the Punch Bowl at a Dance Party. The Party was over in minutes ...... when discussing detergent oil, Croton Oil was real Detergent Oil. |
08-14-2017, 12:57 PM | #56 |
Re: Detergent oil
Were they stuck or collapsed? I'm thinking the later. GM lifters love to leak down in the night so they need to be pumped back up the first few miles of running in the morning. Sounds like a box of rocks in a garbage disposal chatter. Fords from my experience are the other way and collapse once the oil thins out. Both problems caused by seals that are worn out.
08-14-2017, 04:06 PM | #57 | |
Re: Detergent oil
08-14-2017, 10:47 PM | #58 |
Re: Detergent oil
thats what make them hydraulic - tappets or solid lifters are just that. no cushioning effect and thus must adjust valves and worry about zinc levels in modern engines (jeeps 4.0 straight 6 for example)
https://www.youtube.com/watch?v=lorANZ1Tptw crude but shows how a hyd lifter works - some have seals some are extreme tight machining processes that act as a seal but wear increases the gap with time so as oil heats up it sounds like box o rocks cuz no pressure. but yes they can get stuck (generally from too much wear and parts bind) but from what ive seen and experienced they usually are worn out/leaky.
08-14-2017, 10:51 PM | #59 |
Re: Detergent oil
08-14-2017, 11:26 PM | #60 |
Re: Detergent oil
Are we really slipping that much with just a little over 2,000 viewers for this round of Detergent Oil?
Some times back the subject "Oil Change" hit over 14,000. White Wall Tires might still be in the lead .... they topped 15,000 viewers. "Air filters" & "MMO" did not do bad either. |
