I don't know much about motor driven ahoogh horns. My question is: Does the polarity make a difference when connecting the battery and horn button wires to the horn? It seems like the motor would rotate in different directions depending on the +6 polarity.
Rusty Nelson |
No it doesn't matter -the horn is not polarized.
Jon in Ohio |
the noise makers, the gear and the diaphragm, doesn't care in what direction it turns..
It's a series wound motor, so it turns the same direction which ever way you runs the wires.
Rusty,
Tom and the others are correct. It does not matter. Hook up your wires and begin to enjoy "The sound that was hear around the world". Neil THE HORN MAN 601-469-0878 |
Rusty Nelson |
Hey Rusty, the horn IS a DC motor and is polarity dependent, BUT, because the motor only rubs the button on the diaphragm, it can do it in either direction, so it doesn't really care which way it is hooked up, BUT remember this, if you hook the Blue/Yellow to the right side terminal and tune the horn, be sure to always hook that wire to the same side because if you turn the wires around, it will work, but you will need to retune the horn for running in the other direction due to break-in wear.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
Tom is correct. Regardless of polarity wiring, the armature will always spin in the same direction.
Now see, you took ALL the fun out of him trying either direction to see IF the horn indeed needed to be retuned.
Some people..... ![]() ![]() See, what I suggested would cause NO harm, and would be a teaching experience. This is how folk learn about the car and retain that knowledge.
You mean Ahooooga would not sound like agooooha?
Thanks Bill G (Magicbox51). LMAO
Let's let pylons, be pylons! |
A series wound DC motor, such as the Model A horn and starter will always turn the same direction, no matter which way the battery is connected,
To change the armature direction, either the field windings, or armature windings need the polarity changed is relation to the other. A DC motor with a permanent magnet will change direction when the battery polarity is changed because the permanent magnet never changes polarity. Some of the newer car starters are now using permanent magnets, as are the window motors heater motors, and door lock motors. |
#13 |
duplicate message
#14 |
As always Tom, you're correct.... and just to avoid confusion that goes for the southern hemisphere too
