Old 04-06-2017, 12:14 PM   #1
H. L. Chauvin
Default Re: HELP: ready to start again...n/g
Florida ... humidity ..... Springtime or Fall ..... cool nights ...... warm moist days .... unconditioned garage ...... warm moist air condensing on many different cool metal electrical connections causing metal oxidation on metal wire connections retarding electrical flow ..... can happen occasionally in only five (5) months when Model A is not in use ...... multi-meter electrical check from battery to plugs never a bad idea in addition to moisture in fuel.
From years of experience: Used on wire connections located on half mile high coastal communications towers .... expensive because of large 8 oz. container, (used to have 4 oz.); but, will protect and end all Model A "exposed" electrical connection problems for almost eternity.
Kopr-Shield TM Compound-The copper colloidal surface treatment that protects, lubricates and enhances conductivity between all electrical connections. Catalog No: CP8-TB, Codale Item No: 8777, UPC: 78621080636T&B CP8TB 8OZ CORROSION INHIBITOR Kopr-Shield
Price: $18.98 ea
H. L. Chauvin is offline   Reply With Quote
