Old 03-07-2017, 09:19 PM   #1
dave11
Default hood differences
Is the hood design from a 28-29 different from one used on a 30-31?
Dave Eddie
dave11 is offline   Reply With Quote
Old 03-07-2017, 09:23 PM   #2
daveymc29
daveymc29's Avatar
Default Re: hood differences
See the Judging Standards. Simple answer is yes, quite different.
daveymc29 is offline   Reply With Quote
Old 03-07-2017, 09:38 PM   #3
CarlG
CarlG's Avatar
Same idea, different dimensions.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-07-2017, 10:00 PM   #4
SteveB31
SteveB31's Avatar
Also, 4 different hoods in 1928-1929. All 1930-31 hoods are the same.
SteveB31 is offline   Reply With Quote
Old 03-07-2017, 11:12 PM   #5
dave11
On my 30 coupe the length at the top of the hood side aprons measure 31.5" at the top.
30" at the bottom measuring front to back. This leaves a 1/2" gap at the bottom.
Is this standard with a 30 hood? or do I have the wrong hood ?
Old 03-08-2017, 11:42 AM   #6
Bob C
I measured one and came up with 31" at the bottom and 31 1/2" at the top.
Bob
Bob C is online now   Reply With Quote
Old 03-08-2017, 11:53 AM   #7
Keith True
Keith True's Avatar
I have four here less than 10 feet from me.They all measure 31 at the bottom and 31.5 at the top.The gap isn't the hood,it is a sagging body or frame that causes that gap.
Old 03-08-2017, 12:11 PM   #8
George Miller
George Miller's Avatar
Sounds like you frame is sagging at the rear motor mount, a lot of them do. No one wants to check the frame because they think they are ok.
George Miller is offline   Reply With Quote
Old 03-08-2017, 12:13 PM   #9
Tiny
Tiny's Avatar
The standard 28-29 hood, The early 28 hood, the four door hood, what's the 4th one Steve?
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 03-08-2017, 03:32 PM   #10
dave11
Not the frame, which was I had thought. I removed the body, checked the frame for sagging, it was not bad, less than 1/8" of sag, so I straightened it, now it's as close to perfect as I can get. Shimmed the body, it was missing the rear body blocks as some of the rubber pads.
Put the hood back on,....the hood fit looks not a lot different than when I started.....Damm !
