Old 01-02-2017, 02:07 PM   #1
Smooth_One
Smooth_One's Avatar
Default Re: Daily driving suggestions.
Originally Posted by 1930-fordor View Post
I have shared this before, but it is worth repeating.
A gentleman with over 100k on his model A,
advised me that most all break downs will be associated with the distributor. For the sake of time have a spare distributor. Install it and have points set and make sure it works well. Then keep it with car. If you break down on the side of the road, and you suspect it could be timming related. You can change the distributor in about 4 min. Don't spend a lot of time on the side of the road trying to change points or condenser. You can figure out what went bad back at home when it is more convenient. It is a little pricey, but if you are broken down on the side of the road in unfavorable or unsafe conditions, it is worth the insurance.
This is a good idea not thought about by many.
Smooth_One is offline   Reply With Quote
