Re: Mitchell Overdrive - noise to expect
The OD is on my 1941 coupe, had it put on by pro who never did one of these before so was anxious to do one. According to info given, the lever on the OD should face straight down or up however you decide you want to assemble, up or turn unit around and it will face straight down. I noticed mine faces at slight angle from straight down when OD IS ENGAGED. I SAW THIS WHEN I LOOKED UNDER CAR IN GARAGE TODAY. BUT THINKING ABOUT IT ACCORDING TO INSTRUCTIONS, YOUR SUPPOSE TO PUT OD IN NEUTRAL THEN ADJUST LINKAGE SO IT FACES DOWN.?.? I'm not too swift on this set up, I'm a DIY guy learning about flatheads and OD'S any help appreciated. John
