Old 10-15-2016, 12:16 AM   #1
expavr
expavr's Avatar
Default Re: FINALLY…T5 WITH Torque Tube in a ‘35-’40 Ford...The WHOLE STORY!
Well thought out and designed!!! My hats off to both of you. There is one question: Looking at the location of the shift tower on the T5 Trans it looks like the shift arm will protrude thru the floor well back into the cab of the truck. How close to the seat did it end up being?
Les Williams
expavr is offline   Reply With Quote
Old 10-15-2016, 07:14 AM   #2
Heard
Heard's Avatar
Les Williams
You can see about where it will come out in relation to the front of the seat by looking at the holes in the frame member here and comparing to the first pics DD posted.
Heard
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 10-15-2016, 12:30 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Les Williams
As Heard pointed-out, compare the two pictures. In his pic of the seat bottom, the T5 shifter will come out of the floor just slightly forward of the mechanical brake arm that has all of that bailing wire wrapped-around it. Compare the square and round holes in the frame rail. I estimate that it's roughly 6" or 7" behind the stock Ford location. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-30-2016, 03:32 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Les Williams
Hey Les.......Heard just put his cab back on the frame so that he could take a couple of measurements and answer your question with accurate info. Pretty slick, huh? DD
T5 W/TORQUE TUBE
