Old 09-15-2016, 09:43 PM   #1
Coneross-A
Coneross-A's Avatar
Default 221 V8 Engine Oil Recommendation
Hello All,
I'm new to the Early V8 world. I just bought a 1936 1/2 ton pickup with a 221 V8. I pick it up tomorrow, and one of the first things I am going to do is change the oil. Any recommendations for a good oil for these engines?
I've been on Ford Barn for a while in the Model A forum. [Now I own 12 antique cylinders ] I use Brad Penn - Penn Grade 1 40 weight in my Model A. It includes zinc and phosphorous additives. Any thoughts on this oil?
Also....how often should the oil be changed?
Any thoughts would be appreciated.
Coneross-A is offline   Reply With Quote
Old 09-15-2016, 10:00 PM   #2
Mike in AZ
Mike in AZ's Avatar
Default Re: 221 V8 Engine Oil Recommendation
welcome to the V-8 section....lol....posts some pics of your peekup when you can.....Mike
Mike in AZ is offline   Reply With Quote
Old 09-15-2016, 10:02 PM   #3
JSeery
JSeery's Avatar
There are just about as many preferences in oil are there are folks pouring oil in. Might do a search of past post/threads if you want to dig through all the bloody details.
Old 09-15-2016, 10:24 PM   #4
Talkwrench
Talkwrench's Avatar
lol.
Old 09-15-2016, 11:17 PM   #5
Brian
Brian's Avatar
Welcome to V8's! Use the same oil; it'll be fine. Oil change frequency same as your Model A.
Old 09-16-2016, 12:49 AM   #6
Drbrown
Drbrown's Avatar
Ditto regarding forum opinions about brands and viscosities of oils .... we form our own opinions. Note that the temperature climate one lives in and your engine operating temperature may affect the decision about viscosity.
Ford '41-'48 lube charts of the day say every 1000 miles. Non-detergent oil was prevalent then and into the 1950-1960's and even then manufacturers (and oil companies) were still saying every 1000 miles with filters to be changed every 5000. Far cry from today when we generally use low-range viscosity synthetic and change oil/filter every 5000 or 7000.
I'm about 2.5 hrs drive south of Montreal Canada. With global warming/climate change normal temperature extremes here have risen to about 0 degrees up to 95. My '47 runs at about 170 degrees, has no filter and I change my Penn 10w-30 at 1000 at which time it comes out fairly clean.
Drbrown is offline   Reply With Quote
Old 10-08-2016, 10:45 PM   #7
Coneross-A
Coneross-A's Avatar
Sorry I've taken so long to get back to responding on this post. Some other pressing issues came up and I haven't had much spare time. I'd like to thank everyone for your responses. For now I am using Rotella 15-W40. It's a little thinner than the straight 40 I run in my A, but it will hopefully help clean up the engine a little before I put straight weight in.
Old 10-09-2016, 10:17 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Welcome to Fordbarn. Very nice looking '36 PU. Oil preference here is a never ending discussion. You can read every previous post on the topic and still not have a conclusion. The Shell Rotella T 15-40w is what I use in my old and modern vehicles. I put a lot of miles on my vehicles, and all is well with these engines, so I will keep using this oil until someone can prove to me there is something better.
John
Old 10-09-2016, 10:43 AM   #9
J Franklin
J Franklin's Avatar
I wouldn't use straight weight oil nor 40 wt. 10-30 or 10-40 are my choices for good flow and long engine life.
Old 10-09-2016, 10:54 AM   #10
tubman
tubman's Avatar
I fully agree. And just about any brand will do. Remember this is a flathead that is already broken in with low valve spring pressures. I don't know the exact numbers, but I'll bet any currently available automotive motor oil has more zinc than what was in the oil when these engines were new. I am now buying my motor oil at Dollar General for less than $3.00 per quart. The only thing is that it says "Do not use in any vehicle manufactured after 1985". That's good enough for me. I just wish they carried filters.
Old 10-09-2016, 12:59 PM   #11
AnthonyG
AnthonyG's Avatar
I agree with J Franklin, the multi viscosity oils in a 10-30 or 10-40 offer better flow especially on start-up when your engine is still cold.
Very nice '36 P.U.!! Good luck and have fun with it.
Nomad
AnthonyG is offline   Reply With Quote
Old 10-09-2016, 05:04 PM   #12
Capt Kirk
Capt Kirk's Avatar
My engine is fresh and ready for an oil change. My pressure was reading low (like 0 at idle hot) on the stock dash gauge. I got recommendations to run 20-50 from some on here but that's never been a weight that I've seen at the parts store. I believe my M***'s sender is the culprit so I'm not to worried about it now. I don't drive it in the winter so it's 15-40 for me. I run Delo in my diesel and Aeroshell 100 in my plane...have never had an engine failure in anything because of oil type or brand. The lubricants we have now are way better than what was available back in the 30's. I'd suggest that you get a weight of oil suitable for your region and your driving habits and pick a brand that you're comfortable with. I once topped off with a couple quarts of chain saw bar oil (had no choice) and that engine is still happily running with over 200K miles on it.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 10-09-2016, 10:12 PM   #13
Coneross-A
Coneross-A's Avatar
Thanks for the advice guys. I'll stick with the Rotella 15W40 for now. I've noticed that the oil turns black quickly. I have no history on this engine. Oil turning black possibly because previous owner didn't use detergent oil, or there may be a layer of crud on the bottom of the oil pan. I had that issue with my 29 A. Dropping the oil pan on the V8 engine appears to be a bit more involved than a Model A.
At any rate, it doesn't seem to burn oil, which is good.
As I've driven and tinkered with this truck, I've come across some additional "surprises". I'll be hitting you guys up for advice on those too once I get all my thoughts collected on each issue.
Thanks again for your help.
PS: I know the wiring in the pics looks bad...that has all been replaced.
Old 10-09-2016, 10:28 PM   #14
40 Deluxe
It's funny how we talk about the 'weight' of oil when the "W" stands for "Winter", not "Weight"!
Old 10-09-2016, 10:46 PM   #15
JSeery
JSeery's Avatar
Very true! The "w" is often misused, not only in relationship to being confused with "weight" but also with which viscosity numbers it ends up connected with in some post.
Old 10-10-2016, 01:08 PM   #16
AnthonyG
AnthonyG's Avatar
In line with 40 Deluxe & JSeery, should anyone have an interest here's a good explanation reference;
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Nomad
