Old 08-25-2016, 08:28 AM   #1
Bulligen
Bulligen's Avatar
Default Re: 97 Carb Fuel Bowl
My neighbor brought over an extra regulator that had a gauge on it and connected to that only, plugged at the other outlet the gauge read 3.1 lbs. I put a cheap regulator on it and will check it again. Do you think the pump in sucking air from the fuel tank?
Bulligen is offline   Reply With Quote
Old 08-25-2016, 10:00 AM   #2
Willit Stop
Willit Stop's Avatar
You mentioned that the carburetor is new.Maybe you could swap it out with your old one and see if there is a difference. Just a thought.Sometimes, new doesn't mean good.
Willit Stop is offline   Reply With Quote
