Old 07-28-2016, 08:10 AM   #1
imacrazy
Default Inline gas shut off
Gentleman, what kind of inline gas shutoff valve to you all use, and where can you buy them.
Thanks again.
Bill
imacrazy is offline   Reply With Quote
Old 07-28-2016, 08:42 AM   #2
Jay's Model A's
Location: New Braunfels, Texas.. Member of Alamo A's, MARC & MAFCA
Default Re: Inline gas shut off
I use a S/S (stainless steel) 1/4", 5/16" or 3/8" Ball valve and I get them from Ace Hardware.. There are not many "Big Box Stores" that carry them but your older / smaller hardware stores have them.. It is sometimes easier to also go to copper tubing because of the small distance you have to work in.... Jay
Jay's Model A's is offline   Reply With Quote
Old 07-28-2016, 09:26 AM   #3
wrndln
I had a leaking gasoline shut off valve on my snowblower. I replaced it with the valve shown in the picture below. That was about 4 years ago and it still works fine. I believe I bought it on eBay for about $4. The same valve should work on a model A with some rubber hose connections.
Rusty Nelson
Old 07-28-2016, 09:56 AM   #4
CarlG
CarlG's Avatar
I got this one from Amazon: (¼" Brass Ball Valve)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-28-2016, 10:08 AM   #5
katy
katy's Avatar
What are you working on?
On a Model A, I use the stock Ford valve.
In other applications I've used ball valves.
Old 07-28-2016, 10:19 AM   #6
C26Pinelake
Why change from the original style ? Rebuild it if it leaks! Wayne
C26Pinelake is offline   Reply With Quote
Old 07-28-2016, 11:25 AM   #7
Russ/40
Russ/40's Avatar
Carl, does that valve rely on a Teflon seat for the ball?
Old 07-28-2016, 01:34 PM   #8
mshmodela
mshmodela's Avatar
One item that came with my Late 31' was an addition Inline gas valve, --yes not historically accurate but I know the gas will surely be cut...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-28-2016, 02:58 PM   #9
CarlG
CarlG's Avatar
This is what the description says:
Brass for corrosion resistance, ductility at high temperatures, and low magnetic permeability
Lever handle for manual on/off control
PTFE seats and stem packing reduce the risk of leakage
Maximum pressure rating of 600 psig for WOG and 150 psig for WSP
Female NPT threads for connecting to male threaded pipes
Alaskan A's
Old 07-28-2016, 07:52 PM   #10
glenn in camino
glenn in camino's Avatar
I got mine from Brattons, Works fine,
Old 07-28-2016, 08:57 PM   #11
C26Pinelake
But you must admit it looks terrible on a Model A! Wayne
Old 07-28-2016, 09:46 PM   #12
Gyrodoc
Gyrodoc's Avatar
Why do you need two?
Richard
Gyrodoc is offline   Reply With Quote
Old 07-30-2016, 06:16 PM   #13
imacrazy
Thanks to all of your input. Sure good to talk A's
Bill
Old 10-02-2016, 12:39 AM   #14
Dutie
Dutie's Avatar
I have the same positive shut off valve from Brattons and it works great. The conical shut off valve on the firewall would leak just enough to be an issue with my new float valve and there would be a wet spot on the bottom of the carb. Problem solved
Dutie is offline   Reply With Quote
Old 10-02-2016, 05:56 AM   #15
H. L. Chauvin
FWIW: Soft Copper Fuel Lines:
1. As a teenager in the 1950's, I had an almost straight soft copper gas line from my Model A 1930 Coupe settlement bowl to my carburetor, except for the 90 degree bends at both ends.
2. I was advised by my mechanic Dad, (born 1902 who knew T's & A's plus all of the other 1920 & 1930 cars back then), to put a 360 degree loop in this copper line mid-way to keep this soft copper line from flexing, experiencing metal fatigued, and breaking at one end or the other.
3. It was a driver where I drove it every day on unpaved roads and I did not heed his warning.
4. About a year later the copper line fractured at the carburetor connection, leaked gas, and caught fire while in my yard.
5. I extinguished the fire, placed the recommended 360 degree loop and had no problems afterwards.
6. Fortunately I was not out on a highway in traffic when it happened; but this was my first Model A lesson learned from an "experienced" vintage mechanic born in horse and buggy days.
7. It takes only once to learn rare accidents do not happen often .... but after they do, just once .... and we "almost" get burnt .... some of us like my Dad & I, usually re-evaluate our mechanical safety concepts & try to alert others about it.
H. L. Chauvin is offline   Reply With Quote
Old 10-02-2016, 07:07 AM   #16
George Miller
George Miller's Avatar
I also would never use copper lines for gas or brakes.
George Miller is offline   Reply With Quote
Old 10-02-2016, 11:59 AM   #17
H. L. Chauvin
Also, years ago in the Model A "Secrets of Speed" Magazine, Mr. Charles Yapp warned against using copper lines in "full-oil-flow" Model A engines from the oil pump to the main bearings because of experienced metal fatigue with vibrations followed by copper tube failure.
But, also, after a few warnings, cigarettes are still used by the daring "try & see" group.
Old 10-30-2016, 09:36 PM   #18
Dutie
Dutie's Avatar
I am with George, never copper and never ever rubber !
Old 10-30-2016, 10:07 PM   #19
00fxd
A "Working Coil". Commonly seen on many steel brake lines at the master.
00fxd is offline   Reply With Quote
