Old 07-28-2016, 01:24 PM   #1
chuck stevens
chuck stevens's Avatar
Default trans up date to over drive
I know it probably has been done before but just had to post this anyway. This trans is 50 mercury with a borg warner overdrive, I know they have stronger syncros and better ratios than the old top loaders of the mid thirtys. I'm hopping to install this set up along with an 8BA in a 34 so I came up with this. The heavy angle on the right side with be home to the e-brake, just like the top loader. It seems to shift good on the bench, time will tell, Chuck S.
chuck stevens is offline   Reply With Quote
Old 07-28-2016, 01:53 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: trans up date to over drive
Chuck.......I'm not sure what type of transmission you're showing there, but the one shown below is a '49-'50 Mercury O/D. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-28-2016, 02:20 PM   #3
tubman
tubman's Avatar
Looks to be a '51-'53 Ford or Mercury to me. The fact that it does not have the integral bellhousing (and therefore the early style clutch linkage) will make hooking up the clutch more difficult than normal.
Old 07-28-2016, 03:14 PM   #4
Bob C
Here's a 49 Mercury that that was posted before.
Bob
Old 07-28-2016, 03:24 PM   #5
John R
The main case definitely is 51 Ford. The OD I'm less sure about, but does not appear to be 49 - 50 Ford.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 07-28-2016, 03:38 PM   #6
40cpe
40cpe's Avatar
I think the point of the post is the clever conversion using a toploader shifter.
Old 07-28-2016, 04:04 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Yes, I agree that that was Chucks main point. I have seen that converstion of early top loader shifter tops on the later side load transmissions before. May have been a post on the old Fordbarn when Shelly owned it. The discussions covered doing it the way Chuck has his, vs. some of the commercial aftermarket shifter conversions, i.e. Hurst, and others. Those old FB posts are probably now lost somewhere in cyberspace.
John
Old 07-28-2016, 05:09 PM   #8
RobR'35
RobR'35's Avatar
I'm very new to this all. I'm curious though when the old FB is mentioned. What years were those? I find it sad that that info is gone.
This conversion is very cool by the way.
RobR'35 is offline   Reply With Quote
Old 07-28-2016, 05:27 PM   #9
expavr
expavr's Avatar
John
Are you thinking about the modified shifter on the 49 Merc O/D trans in my truck? https://www.fordbarn.com/forum/showthread.php?t=156620
Chuck's version shows that's there more than one way to skin a cat...
Les
expavr is offline   Reply With Quote
Old 07-28-2016, 05:35 PM   #10
rotorwrench
rotorwrench's Avatar
He could use the late 1951 Mercury bell housing for that. It has a direct bolt up for the later 51 & up Borg Warner pattern and it has a rotating clutch release mechanism that could easily be made to work in an early Ford. I also always liked the fact that it has a little removable dust cover pan so a person can look at the clutch. Put a Borg & Beck clutch on and go to town. Those late 51 Merc bell housing are a one year only deal so I don't see them on the flea-pay very much and even then they are usually missing the dust cover pan. They also used a different throw out bearing but I've seen those offered for sale at several vendors sites.
Old 07-28-2016, 06:13 PM   #11
JM 35 Sedan
Originally Posted by expavr View Post
John
Les
I believe that is the one I am thinking about, or at least one of the best ones I saw back then. Did you make the original post on that several years earlier?
John
Old 07-29-2016, 07:04 AM   #12
chuck stevens
Thanks for the kind words, I'm not sure what year the trans is, it was a flea market find last winter in Florida. Les, you're set up looks much cleaner than mine. The biggest problem I had was getting the detentes of the top shifter to coordinate with the side loader detentes.... extra holes in the levers and adjustable linkage. This will be set into place without the body so the clutch set up will be easier, Chuck S.
Old 07-29-2016, 09:26 AM   #13
expavr
expavr's Avatar
Chuck
If the detents continue to be an issue consider using a spring with lighter pressure in the detent galley in either the shift tower or the trans. It will make shifting a whole lot easier. I chose to do it in the shift tower to insure that one of the detent balls didn't inadvertently drop into the transmission due to the reduced pressure. PM me. I'm curious about your design, especially how you dealt with the horizontal brackets from the shift tower to the transmission wanting to rotate on the axis of the sliding shafts in the tower and how you modified the forks to attach the horizontal brackets.
Les
Old 07-29-2016, 12:21 PM   #14
Anton Voycheck
Anton Voycheck's Avatar
Prior to 2010. The old old Ford Barn was a bulletin board type forum. The archives for some old Ford Barn posts can be found at the bottom of the home page for this forum.
https://www.fordbarn.com/forum/forumdisplay.php?f=27
Anton Voycheck is offline   Reply With Quote
