Old 07-15-2016, 06:53 PM   #1
woodypecker
woodypecker's Avatar
Default Re: blower on a 4bbl intake
I used a one inch plate with a fifth hole in the middle and have a pop off valve on the side of the manifold and I needed it on first drive due to magneto and carb problems. I run a max of 4 psi of boost with two 5/8 belts. Be sure and use the old style manifold where the carb mount surface is parallel to crank. The plate sits on top of the front of the manifold with a couple of gasket pieces as a shim. To date it has survived about 500 miles.
woodypecker is offline   Reply With Quote
Old 09-15-2016, 06:44 AM   #2
ssaza25
I have an old Magnuson blower that is design to mount to any 4 barrel intake. A very cool blower. It has a plate that bolts to the 4 barrel intake then the blower has 2 holes in-between the twin blowers that bolt to the plate. A very simple set up.
ssaza25 is offline   Reply With Quote
