I calculated your CR as 8.8:1.This is alittle hi for 87 Oct gas. However, using a latr ignition system you might get away with it. The advance curve is critical.
Hello Ron, I thought about 7.5:1 C.R. I'll have to work it out now that you've said. Our gas here is either 91 or 95 with 98 available (98 is ethanol)
I will be running a crab dizzy. Thanks for the warning Ron. I was just going to run it. |
Years ago I got a set of steel shim gasket, I cain't remember where I got them, I think it was in Texas, I think you could get them .010--.020 thick. Maybe someone remembers where they are. Walt
