Old 07-02-2016, 07:27 AM   #9
Bluebell
Default Re: How do I measure a small piston to head clearance
Hi Brian, the heads you sold me are fine. The "grief" is not un-expected. I will do some measurements over the next few days and get back to you.
Your offer is great and I will probably take you up on it. I will give you a call tomorrow.
My 4dv8, there's not much to tell. It is a C69A block with new French rods and the Ross pistons. other than that it is standard. With the heads from Brian and the 3 5/16" bore it should have a C.R. of about 7.5 or 7.6:1.
I am doing it to go in a Bren carrier.
The idea was to increase the cubes a bit, so as to get a bit more torque down low. a carrier weighs about 3 1/2 ton, so the FHV8 works hard. Especially while turning.
Bluebell is offline   Reply With Quote
