I got my '51 Merc engine running, and it seems to be in better shape than I could have hoped; good compression, good oil pressure, no noises, and doesn't overheat. The only problems are a slight oil leak at the front main seal and a larger one at the rear main seal. I went through my extra gasket sets and found some seals. I have both the plain rope seals and graphite-impregnated seals for the front. Any opinions on which would be better to use? I think the graphite ones are newer, but that doesn't necessarily mean they're better. I only have the rope seals for the rear. I have both the teflon-coated and plain seals. Any opinion on which of those is better?
Also, it looks like I can't replace the upper rear main seal without dropping the crankshaft. Given how well this runs, I'd rather not disturb the rotating assembly. I seem to remember back in the day there were long thin spring steel shims that could be pushed in behind the old seal to tighten it up. Is there such a thing, and if so, are they worth using, and where can I get one? |
Tman
You can use a T handled corkscrew to remove the upper rear main seal. My grandfather taught me to use cotton string for the replacement upper seal. Push it in and pack it tight with a wooden chopstick or something similar, using a small hammer. if you do not have the cotton string you can get some from the butcher, they use it for tying roasts. Bruce
Works good Lasts long time |
Be sure you're not over-filled with oil before replacing seals.
Lonnie |
Bruce,
I never heard of the cotton string deal. I never liked the idea of trying to replace the main seal with the crank in place; they're difficult enough with the crank out. Anybody remember the "spring steel strip" deal? Lonnie, Four quarts of 10W-30 with a pint of MMO and a pint of Seafoam. It was right on the "full" mark on the dipstick that I have every reason to believe is the original. Tubman |
Well, okay. is the oil pan clean?
Lonnie |
Lonnie,
It's a Ford pan (the engine is going in my '51 Ford). I cleaned it thoroughly before I installed it. I ran the engine for a few hours with the 10W-30, MMO, and Seafoam concoction in it. When I pulled it the second time, There was a fair amount of sludge in it again. Kinda surprising. Not enough to cause a capacity problem, though. When I swapped the pans, I kept the dipsticks, tubes and pans together as a set; in my recollection, they were the same, however. "Fordwife", If you can find it, I'd be interested in looking at it. Last edited by tubman; 06-04-2016 at 10:55 PM. |
Yes, I remember the steel "shim" kit. Those I used had various size spring steel wires with a guide tube that held the wire straight while a "punch" was inserted into the guide. The wire was forced(hammered) into the seal groove between the original seal and the metal. The wire diameter was selected based on how much leakage was being exhibited. This system worked very well and MANY used cars were sold with dry oil pans.
Thanks, JWL, that's encouraging to hear. I thought I wouldn't be the only one who remembered these. Now the question is : are they still available, and where?
I would appreciate any leads on these; the first few pages of "Google" didn't give me anything. Also, anyone have an opinion on whether the graphite impregnated seals are superior to the plain rope ones? Last edited by tubman; 06-05-2016 at 09:04 AM. |
On the front seal, Speedway sells a one piece one that works well.
I have heard good and bad things about those. I hear they don't fit the cavity well and require a bunch of silicon sealer to set them in place. There is also the question of whether or not to install a new sleeve on the crankshaft. The front leak was very small and I already have a new graphite seal kit with installation "tools" and instructions, so I think I'll go that way. My main concern is the rear seal. I'm doing some on-line research now. I did find a reprint of a Hemmings article that mentions the steel shim repair kits, but goes no further. I'm gonna call my machist tomorrow and see what he has to say.
The sneaky pete tool is made by Lisle and is available on amazon. There are several posts about it online.
#13 |
#14 |
Maybe I am confused here. When I replaced the rear main seal on my 8BA I simply rotated the aluminum upper seal keeper out of the block, pressed the new rope seal in it and rotated the keeper back in place. No problems at all. Really quite simple and worked great. Used the white teflon seal.
#15 | |
![]() Quote:
#16 |
Be careful Tubman. They are not always that loose and are easy to break.
I found it difficult to get mine out, when the crank was already out! The alloy is like zinc and quite fragile. You can still buy them from the likes of Mac Vanpelt. |
#17 |
Thanks for the warning. I'll be careful. I did go through my stash today, and I found a spare. I think soaking it with a penetrant for a day or two may be prudent.
#18 |
I've had good luck using a wooden dowel and a plastic hammer. A few light taps and they've always rotated right out. Yes, you don't soak the teflon one, just lube the crank real well.
#19 |
"4t8v8". thanks for the tip; I got mine out this afternoon, no problem. I soaked it overnight with "Deep Creep"and hit it with "Freeze-off" when I got to the shop today, just to be sure. I hit it with a dowel and hammer and it came loose and then moved abut 3/4". I was kinda stopped there because the dowel wouldn't go around the corner. I figured out that if I put a slightly over length 7/16" fine bolt in one of the flywheel bolt holes and turned the crank, the seal keeper rotates right out. I put it back in the same way. It looked like the original seal had some old shellac sealer where it fits against the block, so I used it when I put it back in. One tip I can add is to get the seal keeper started in the block before you coat it with sealer.
![]() Us flathead guys are lucky; we don't have to resort to such things a "Sneaky Pete's" for main seals like the other guys. This is one time I think "Ford has a better idea!" |
