Old 05-18-2016, 10:08 PM   #1
miller91
miller91's Avatar
Default Re: Inline filters from mechanical pump...part numbers and placement?
Originally Posted by RalphM View Post
Also napa 3039 will work
Ok for using the stock filter bowl these filters fit...looks like the napa 3039 (WIX 33039) doesn't need a spring to hold it up. Fram CG3 fits and needs spring, not that that is a big deal.
The 3039/33039 on the left has a large flange that seals with gasket on lip of glass bowl, holding it up from the bottom and I assume seals tightly by itself, I suppose with gasket.The Fram CG3 on the right does not have this flange and needs the spring to hold it flush to top of the filter housing.
miller91 is offline   Reply With Quote
