I got my 36 cab without instruments, so I don't have the hardware.
I checked Roy Nacewicz catalog and didn't see them. My dash has goobered up studs (rust, dirt, primer, paint), and I think they might be 10-32 Does that sound right to hold in the speedometer and gauges? |
I'd call Roy and talk to him. If he doesn't sell them ( which I'd doubt) I bet that he could help you. I know this from experience
Good luck! Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford |
that sounds about right.clean a stud off and try one.
The studs on my 39pu for holding the speedo and cluster are 10-32.
I don't think there are any coarse (10-24, etc.) threads on anything Henry built during the early V-8 era, only fine and extra-fine threads.......Bob L
Roy Does have them for sure
The instrument studs are for sure 10-32. Ace carries the hardware you need. I just did this work on a 36 1 1/2 ton truck. Had to repair for one stud that was broke off. Drilled and taped to use a screw instead.
I can't get a 10-32 to thread on, but I can get a 12-24 to go on.
I have 1 or 2 studs broke off, not sure, afraid to look up and behind to find out if its more than that! |
#12 | |
![]() Quote:
So you were abke to get a drill up behind the dash and drill out the broken one? Did you need to use a right angle adapter? |
