Old 01-25-2016, 09:23 PM   #1
CT Jack
CT Jack's Avatar
Default 29 2 Tooth Steering Column
Looking for a 29 2 tooth steering column restored or restorable. We are working on a 29 AA fire truck for a local volunteer fire dept. and would like to replace the original 7 tooth column which is badly worn. We do not want to restore the present column as it appears to be a waste of time and money. This is an open truck and removing the column is very easy plus we have to keep the original steering wheel. Will a 29 2 tooth steering box bolt up to the existing column? If this can be done then all we would need is the 2 tooth steering box.
CT Jack is offline   Reply With Quote
Old 01-26-2016, 12:21 AM   #2
Pmsqrd
Pmsqrd's Avatar
Default Re: 29 2 Tooth Steering Column
I will bolt in but the steering wheel and horn rod will also need to be changed. The two tooth wheel is keyed while the seven tooth is splined. The seven tooth horn rod is longer.
Pmsqrd is offline   Reply With Quote
Old 01-26-2016, 09:52 AM   #3
CT Jack
CT Jack's Avatar
If I find a complete 29 2 tooth box and column shouldn't the 29 steering wheel I have fit or do the late 29's use the 30-31 keyed shaft?
Old 01-26-2016, 10:03 AM   #4
Rowdy
The early 29 2 tooth had a splined steering wheel like the 7 tooth. I think this was changed sometime in the April/May time frame. After that it had a keyed shaft same length as the 30-early 31 2 tooth. The tube had the 29 styled quadrant. Ford made a 29 styled keyed wheel for use with this shaft. Decent repops lf the 29 keyed wheel and correct length light switch rod are made for use with these. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 01-26-2016, 10:08 AM   #5
Pmsqrd
Pmsqrd's Avatar
The seven tooth units all used a multi splined wheel which will not work with a keyed shaft that the two tooth has. If you do not care so much for a completely original look, you could look for a 30-31 unit that includes a steering wheel. They are more common than 29 two tooth units and will bolt right in and work fine. This is a common practice for 28-29 touring class cars due to the scarcity of the 29 two tooth unit.
Old 01-26-2016, 12:03 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
There's a good chance Bert's has a 1929 two tooth steering with or without the steering wheel.
Old 01-26-2016, 06:22 PM   #7
29spcoupe
29spcoupe's Avatar
There is a rebuilt 29 two tooth on ebay right now.
29spcoupe is offline   Reply With Quote
Old 01-26-2016, 07:31 PM   #8
Vic in E-TN
It took me over a year to find a '29 2-tooth column for my CCPU. Get one when you can.
Vic
Vic in E-TN is offline   Reply With Quote
Old 01-26-2016, 08:32 PM   #9
700rpm
700rpm's Avatar
Why not rebuild the existing 7-tooth? It's not difficult, and I wouldn't expect the fire truck would get so much use that it would ever wear out again.
Ray Horton, Portland, OR
Old 01-27-2016, 10:28 PM   #10
pgerhardt
pgerhardt's Avatar
Here is the link:
http://www.ebay.com/itm/1929-model-a...Wp-sc&vxp=mtr"
pgerhardt is offline   Reply With Quote
Old 01-28-2016, 06:41 PM   #11
Dale G.
Dale G.'s Avatar
You have a guy named Barnes right there in Ct. that does a great job re-building 7 tooth steering boxes, sectors and all if a person wants. I don't have the number but maybe guys from Connecticut can chime in.
Dale G. is offline   Reply With Quote
Old 02-03-2016, 02:38 AM   #12
RHD
RHD's Avatar
Have a great RHD here.
R.H.D.
Silence is golden unless you have kids, then silence is suspicious.
RHD is offline   Reply With Quote
Old 02-03-2016, 03:08 AM   #13
redmodelt
redmodelt's Avatar
As far as I have seen the 29 two tooth used a single key not splined shaft. The wheels were the same style but the mounting was different.
Re "Will a 29 2 tooth steering box bolt up to the existing column?" No
The 7 tooth is welded together as one assembly where as the 2 tooth is built up.
Unless the column has cracks in it, I would agree that rebuilding the original to the fire truck would be a good way to go esp it you want to keep the original steering wheel. While there were posted several links to ebay ad's, I don't think there are a lot of proper 29 two tooths out there and unless they are restored could get costly to do so also also knowing what to look for that makes it a 29.
Old 02-03-2016, 07:00 AM   #14
mlp623
mlp623's Avatar
Yes, Bob Barnes in Stratford. I have one from him and it is great. Ad in the Restorer - 203-375-7641.
mlp623 is offline   Reply With Quote
