Old 09-20-2015, 11:47 AM   #1
cp5491r
cp5491r's Avatar
Default No spark at distributor
Help please- I'm not good at electrical.
1930 Tudor:
I've got 6 volts at the passenger side of the coil and only 0.3 at the driver's side post of the coil with the key on. Is that correct? No voltage at the end of the wire that goes into the top of the distributor. I've pulled the gauge panel and nothing seems to be shorted out. Am I missing something simple?
Thanks.
cp5491r is offline   Reply With Quote
Old 09-20-2015, 12:03 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: No spark at distributor
Remove the secondary [ high tension] coil wire and hold it 1/4" from a good ground. Turn key on and push on the starter rod, as the engine turns over look for a good spark.
If no spark, remove cap and rotor. With points open there should be battery voltage. When points close there should be no voltage.
If no voltage with points open then look for the problem from the points arm back thru distrbutor contact, coil and key switch.
If voltage at points arm when closed, clean points contacts and make sure fixed contact is properly grounded.
Try these first, if they don't work let us know and we'll continue on for a problem like the plate wire.
Old 09-20-2015, 12:22 PM   #3
cp5491r
cp5491r's Avatar
Thanks. I'll try these ideas.
It's odd. It started yesterday. I ran it for 5-10 minutes and shut it off. Then it wouldn't run again.
Old 09-20-2015, 12:42 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Loosen your distributor cable 1/2 turn, & see what happens.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-20-2015, 01:40 PM   #5
cp5491r
cp5491r's Avatar
I've got the newer distributor plate too but I guess there could be a short there. Headed to garage to check it again.
Old 09-20-2015, 01:50 PM   #6
H. L. Chauvin
FWIW:
One (1) suggestion to try to assist any Model A owner with their future fears of the Model A Electrical Unknowns ....... and one (1) suggestion to try to assist Model A owners to actually "see" the simplicity of a Model A Electrical System:
1. First, try a Forum "Search" for a Model A "Wiring Diagram" if one does not have one.
2. Knowing that one can read a "human-drawn" map with lines representing "continuous" highway routes ....... likewise one can easily read a "human-drawn Model A wiring diagram" which is nothing more than is a "human-drawn" map showing routes of "continuous" wires in lieu of routes of "continuous" highways.
3. The human mind can easily find a "continuous" route connecting Plattsburg, New York with Key West, Florida ....... even after said route traveled "continuously" through many towns.
4. Likewise, with a multi-meter or test lamp, one can easily start at a Model A's source of "energy" ....... i.e., the battery ...... and follow the "human-drawn" diagram of "continuous" route or routes with continuously monitored "energy" to the distributor.
5. If at one point, or after one connection, no "continuous" energy is found, investigation is required ....... if it were a highway, would it be a bridge out, highway surface removed, a pile of trash on the highway ...... with a wire it could be a broken wire, a dirty connection insulating continuous energy flow ..... or whatever.
6. Similarly, this is why 4 year old children can have fun playing games on a cell phone & we cannot ...... no educator convinced them that cell phones are difficult ..... and no educator convinced them that they needed a Degree in Electrical Engineering in order to operate a cell phone.
7. After seeing 4 year olds on our cell phones, no doubt it is a good idea at times to shed our incorrect modern education, to think young again, unlearn a few things, and start from scratch ...... just simple maps.
Hope this helps.
H. L. Chauvin is offline   Reply With Quote
Old 09-20-2015, 03:17 PM   #7
Mitch//pa
here is a diagram if you dont have one
Old 09-20-2015, 03:40 PM   #8
cp5491r
cp5491r's Avatar
Thanks for the input and diagram.
There was no spark and 0.4 volts with points open. I cleaned the connections at the terminal box, and adjusted the cable into the bottom of the distributor. I then had spark and 6 volts with points open. Car started and I ran it several minutes but the ammeter wouldn't show a charge even with revved engine. I shut off the car and tried to start it again and the same problem arose- no spark and virtually no charge when I opened the points.
No amount of screwing the cable into the bottom of the distributor more or less would produce voltage at the points. SO- I'm thinking that the cable from the ignition switch to the bottom of the distributor has a broken wire in it. Reasonable???
Old 09-20-2015, 03:47 PM   #9
Mitch//pa
how about the lower plate wire. or connections of the plate wire grounding int.. moving the advance lever moves the plate wire
another thing to ck is if your running an aftermarket type igntion switch is to insulate the terminal legs from grounding on the gas tank.. back the dash panel off and try
Old 09-20-2015, 05:11 PM   #10
Patrick L.
Patrick L.'s Avatar
Yep, what Mitch said. Also you could remove the primary lead into the distributor and see if its bad. Its somewhat common for the insulation to go bad and short to the outer casing usually right where they screw into the housing.
Old 09-20-2015, 07:00 PM   #11
H. L. Chauvin
FWIW:
If one has a Bratton's Catalog, (any year), Bratton's always showed an Ignition Switch Test Diagram showing how to test the Ignition Switch connections and grounded cable connections at the distributor, with the ignition switch "ON" and "OFF" with:
1. The Ignition Switch marked (A); and,
2. The grounded Armored Cable marked (B); and,
3. The Insulated Wire in the cable, leading to the distributor, marked (C).
Might help someone some day.
Old 09-21-2015, 02:22 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
An ignition emergency jumper is a very handy tool to carry in your car.
Snyder's lists it as A-11576-RK3 for $14.95.
The fact that you have .3 or .4 volts on the ground side of the coil tells me you have something grounding out. As mentioned, the repro key is often the problem when it's contact rubs on the gas tank. If you have an original popout, then the wire inside has 85 year old insulation and has likely worn and the wire is grounding. If the .3 volts is with the key on or off, then I'd say the problem is most likely right at the key switch.
Also, if you have a slant pole coil, be sure it has insulating washers on each of the primary terminals, so it doesn't short to the case. The hardware order is: insulating washer, flat washer, lock washer, hex nut, then the wire terminal and barrel nut.
Old 09-21-2015, 05:04 PM   #13
mhsprecher
mhsprecher's Avatar
I was "helping" a fellow club member last week with a similar problem. No spark from coil. I was helping him during a lunch break and had to get back to work, but I am not the best to diagnose electrical problems. Something I need to brush up on. I enjoyed reading this thread and will look at Bratton's catalog. I need to place an order tonight, anyway. :-)
mhsprecher is offline   Reply With Quote
Old 09-21-2015, 11:35 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
1930 Tudor:
With the points closed, yes points open like with a piece of paper between them, no.
This is the high voltage side that delivers the voltage to the points.
Thanks.
This may help,
https://www.fordbarn.com/forum/showpo...87&postcount=4
Old 09-23-2015, 10:19 AM   #15
cp5491r
cp5491r's Avatar
Thanks for the additional ideas and the drawing!
I haven't had a chance to get back to the storage unit to check the lower plate wire grounding out. I wish I was retired and had more than an hour or so at a time to work on the cars
Old 09-24-2015, 11:05 AM   #16
katy
katy's Avatar
High voltage goes to the spark plugs.
Old 09-25-2015, 12:28 AM   #17
Mike V. Florida
That was a stupid mistake on my part. Thanks for the correction.
Old 09-25-2015, 10:28 AM   #18
katy
katy's Avatar
We all make mistrakes once in a while.
Old 11-08-2015, 07:40 PM   #19
cp5491r
cp5491r's Avatar
I am frustrated on this one. With switch off, I have voltage from starter to both sides of coil. Ampmeter discharges when I try the horn. Took distributor plates (top and bottom) out to look for shorts and didn't see any issues. Replaced the wire from switch to distributor, thinking it might of been shorted out inside the cable, still no spark at the points.
What am I missing?? Thanks.
Old 11-08-2015, 07:45 PM   #20
Mitch//pa
switch on points closed you should have power to one side of the coil
switch on points open you should have power to both sides of the coil
make sure your repo switch legs are not touching the metal gas tank or youll get false readings.
loosen the dash to let it hang away from the tank
