Old 07-29-2015, 10:33 PM   #1
Ray P
Ray P's Avatar
Default Unusual repair
I am starting a ground up restoration for my 30 coupe. After having the body media blasted I was surprised at all the damage that was Suddenly visible. There was the usual rust through, cracked fenders and miscellaneous dings etc. the big surprise though was a weld seam on both quarter panels just above the belt line that runs from the door opening all the way around to the rear roof panel. The apparent weld is highly visible from the inside and somewhat visible on the outside. Any ideas what this may be? I'm only able to attach one pic
Ray P is offline   Reply With Quote
Old 07-29-2015, 10:39 PM   #2
Bulligen
Bulligen's Avatar
Default Re: Unusual repair
Factory Seam
Bulligen is offline   Reply With Quote
Old 07-29-2015, 11:10 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Good evening Ray,
"MAYBE" the car had been rolled over & someone welded on a new ROOF??
I discovered that Vermins' cowl had been replaced, they cut the sub-rails right in the middle of the sill plates. Never know what these old buckets have been through!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-29-2015, 11:12 PM   #4
Drive Shaft Dave
My 30 coupe looked like your's also.
Drive Shaft Dave is offline   Reply With Quote
Old 07-30-2015, 07:18 AM   #5
TommyCoupe
TommyCoupe's Avatar
Mine too.
Tommy-
TommyCoupe is offline   Reply With Quote
Old 07-30-2015, 08:49 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
The outside seam was leaded.
Old 07-30-2015, 11:15 AM   #7
BILL WILLIAMSON
SO, Michael, that's probably why I've seen CRACKS just above the belt moulding, at the "B" post!! !
Bill W.
Old 07-30-2015, 11:44 PM   #8
Mike V. Florida
Could very well be.
Old 07-30-2015, 11:57 PM   #9
RandyinUtah
I also had a welded seam on both sides of the rear panel on my fordor.
RandyinUtah is offline   Reply With Quote
Old 07-31-2015, 06:43 AM   #10
Tinbasher
Tinbasher's Avatar
Factory Flash Welds where the panels are put together.The 30 Coupe I just finished is the same. A neat process where the factory fits the panels together and then passes a current through them and at the joint it makes a weld.
John Poole
Tinbasher is offline   Reply With Quote
Old 07-31-2015, 06:54 AM   #11
larrys40
Ray,
All the coupes were seam welded here at the factory. I have two apart for restoration for folks right now and yes, it is normal from the factory that way. Following blasting the lead is out of the ends of the seams a the front door edge and back where the back panel and seam jount is for the thin body sandwich moulding. It always amazes me how well the seam is finished around the body and the ends are rough... even dinged in and filled with lead. They all are leaded in the leading/trailing edges so don't sweat it. Just use a good grade of filler as a replacement if needed.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 07-31-2015, 07:03 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
Its a factory electric weld seam, and not a repair.
Bob Bidonde
