Old 07-24-2015, 03:33 PM   #1
smittykid
smittykid's Avatar
Question Starter motor removal question
Went to start the 29 Fordor this AM and when I hit the starter button-nothing. Battery is ok, all switches on. I thought it might be the starter switch on top so I removed it and tried it on my 29 Coupe. I noticed that the threaded end of the starter rod was bent. It has been starting just fine. When I tried it on the Coupe it worked fine. It appears I have a problem with the starter motor itself. I followed Les Andrews' instructions on removing it. I got the 3 bolts out (top one last). Tried to lift it up & out. No dice. It's on there pretty good. I'm soaking the seam with B'Laster. How should I break it free? I don't want to damage anything in or on the starter. Should I try to pry it loose with a screwdriver, tap it with a hammer? That starter has probably not been removed in a good 40 years. Any help would be greatly appreciated. Thanks a million! Smitty
smittykid is offline   Reply With Quote
Old 07-24-2015, 03:36 PM   #2
Mitch//pa
Default Re: Starter motor removal question
wack it with a block of wood and hammer
Old 07-24-2015, 03:40 PM   #3
smittykid
smittykid's Avatar
I'll probably be doing this alone. I'm guessing I should thread that top bolt back in partially so when it breaks free (I hope) it won't fall. Where exactly should I "whack" it?
Old 07-24-2015, 03:44 PM   #4
Mitch//pa
i usually wackem on the ass end
Old 07-24-2015, 03:45 PM   #5
Mitch//pa
maybe your bendix is stuck in the ring gear and thats why it wont turn over
can you turn the motor over by hand in neutral???
Old 07-24-2015, 03:51 PM   #6
smittykid
smittykid's Avatar
I'll try that tomorow with the crank and report back.
Old 07-24-2015, 03:53 PM   #7
Mitch//pa
if you cant turn the motor try rocking the car in gear to free it.....
Old 07-24-2015, 04:32 PM   #8
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
I just wanted to put in my 2 cents Leave one bolt in till free. I know from 40 years of working on old great mechanical pieces. Be care full dont get your finger smashed. Don in In.
Indiana A. Lover is offline   Reply With Quote
Old 07-24-2015, 05:44 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Locking starters are just a part of Model A's----------Usually caused by NOT pushing the spark lever to the top, when cranking. Put it in high gear & rock the car backwards, to free it. I'LL GRUNT FOR YOU!---(OOPS, I just farted!) The Dog's LAFFIN'
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-24-2015, 07:30 PM   #10
glenn in camino
glenn in camino's Avatar
First drain the water and remove the water inlet.
Old 07-24-2015, 07:39 PM   #11
700rpm
700rpm's Avatar
Gotta disagree with my friend Glenn. The starter will come out without removing any other parts or draining water. Except maybe if you have an aftermarket oil breather tube installed.
BTW, Glenn, not to hijack this thread, but I installed the molding I bought from you for my coupe, and it looks beautiful!
Ray Horton, Portland, OR
Old 07-24-2015, 08:14 PM   #12
Henry1953
Henry1953's Avatar
I had to hit mine pretty hard with a block of wood and hammer to free it the first time I took it off. Leave the top bolt in part way to keep it from falling out when it frees. Just removed it last week to work on the steering and it came right off this time.
Henry1953 is offline   Reply With Quote
Old 07-24-2015, 08:34 PM   #13
CarlG
CarlG's Avatar
Originally Posted by 700rpm View Post
Gotta disagree with my friend Glenn. The starter will come out without removing any other parts or draining water. Except maybe if you have an aftermarket oil breather tube installed...
If you have an F100 steering gear, the water inlet has to come off to get the stock starter off.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-24-2015, 09:19 PM   #14
mshmodela
mshmodela's Avatar
Smitty, good luck, I pulled mine for the first time 2 weeks ago.. . follow the experts advice above.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-24-2015, 10:59 PM   #15
700rpm
700rpm's Avatar
He didn't say anything about an F100 box, so I assumed it's stock.
Old 07-25-2015, 06:03 AM   #16
Mitch//pa
Happy Birthday Smitty
Old 07-25-2015, 06:54 AM   #17
smittykid
smittykid's Avatar
Thanks, Mitch! I'm going to try & turn the engine over in neutral with the crank later this AM & go from there. Thanks to all for all the help!! I'll keep everyone updated.
Old 07-25-2015, 06:56 AM   #18
Tim B.
I tend agree with the locked starter theory group. If the starter is bad and bendix is not stuck it won't take much of a tap to free it up. You may want to invest in a nice big rubber mallet. I have a nice large mallet with a heavy fiberglas handle that has screw in soft and hard rubber head ends that works great without damaging things. Keep your blows towards the very end of the starter body where it has the most strength and not on the body of the starter that will dent. Give it medium hits alternating between top, bottom and side to rock it loose. Leave the top bolt in place but loose so the starter doesn't fall when it pops loose.
Tim B. is offline   Reply With Quote
Old 07-25-2015, 09:13 AM   #19
smittykid
smittykid's Avatar
Here's my latest update. I put the car in neutral and tried to turn engine over with the crank. No dice, it wouldn't budge. Then I put her in reverse and tried rocking her back & forth. I got about a foot of movement-6" forward, 6" backward but that was it. So I got out the wood block and starting tapping. I got the starter out and have enclosed some pics. I have no idea what to look for. The main shaft seems to turn ok with no grinding noises. It's kind of tight, but it turns. That small gear closed to the starter spins freely on those large threads. Now what? There is a fellow fairly close to me who rebuilds starters. Thanks for all your input so far. Smitty
Old 07-25-2015, 09:24 AM   #20
MikeK
MikeK's Avatar
The Bendix drive spring is severely bent. That's your problem. Caused by kickback while starting.
MikeK is offline   Reply With Quote
