Old 02-13-2015, 07:45 AM   #1
imacrazy
Default Hot Water Heater
I was interested to see if anyone has
installed a hot water heater in there "A."
If so would you pass that information along.
Thanks
Bill
imacrazy is offline   Reply With Quote
Old 02-13-2015, 08:03 AM   #2
juke joint johnny
juke joint johnny's Avatar
Default Re: Hot Water Heater
I Recently bought a Tudor Sedan with an Otwell health heater in it the manifold type ,
The wife was so warm she took her coat off said it was the first time in 30 years of riding
in old cars with me that she had felt too hot!!!
Might be easier and cheaper than the water type heater.
juke joint johnny is offline   Reply With Quote
Old 02-13-2015, 08:29 AM   #3
bettlesr
bettlesr's Avatar
Here's a heater I put under the front seat in my Sport Coupe. My son welded up the box and we cut down a later pickup heater core to fit. The air comes out at about 175°F. The outlets are air vents from a British sports car. There is a third outlet on the box which dumps some warm air under the seat as a seat heater. The picture by the transmission shows the heater contol valve to change the temperature. It us from an old Chrysler vehicle.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 02-13-2015, 08:46 AM   #4
Mitch//pa
nice clean job
i like your setup
Old 02-13-2015, 09:13 AM   #5
imacrazy
I like that set up, had not thought about
putting it under the seat.
Thanks again
Old 02-13-2015, 08:43 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Thanks
Bill
Bill, to razz you a little, why do you need to install a "hot water heater" if admittedly the water is already 'hot'?
Nice job of ingenuity!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-13-2015, 10:14 AM   #7
C26Pinelake
The temperature here last night was minus 20 degrees Fahrenheit. I have installed hot water heaters in four out of give of my Model A cars and they do a wonderful job. The manifold heater might keep the chill down but will not make it warm. Wayne
C26Pinelake is offline   Reply With Quote
Old 02-13-2015, 02:08 PM   #8
imacrazy
Wayne, would you care to show how
you installed the heaters in your cars and what kind of heaters
did you use?
Thanks, Bill
Old 02-13-2015, 03:13 PM   #9
C26Pinelake
did you use?
Thanks, Bill
I got the entire set up from Snyders.i got it complete with the hose, coupling, Heater and instructions. I got the 6 volt because all my A's are 6 volt. If that does not help I can take pics when I can get to my storage barn. We are in the middle of a blizzard and it is minus 22 Fahrenheit and about 30 inches on the ground already. Regards, Wayne
Old 02-14-2015, 08:06 AM   #10
imacrazy
Thanks Wayne, I will check with Snyders. Cold in Indiana today also. Bill
Old 02-13-2015, 11:53 AM   #11
armchair67
Agreed. I drive my Tudor daily and the manifold heater is ok. It works pretty well but we have had a lot of sub zero days here and I have GOT to stop procrastinating and install a hot water heater
armchair67 is offline   Reply With Quote
Old 02-13-2015, 01:45 PM   #12
C26Pinelake
You will be truly amazed at the difference.
Wayne
Old 09-04-2015, 06:58 PM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Bettlesr,
In the #6 pic, is that one of those old adjustable thermostats? I'd sure like to find where to buy them, used them on Flathead V-8's, also.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-05-2015, 09:36 PM   #14
bettlesr
bettlesr's Avatar
Bill:
Yes, that is an adjustable thermostat. Goes from low to alcohol to high on the knob. It was on the car when I bought it and there are no manufacturers marking on it. It does work great.
Dick
1965 Lotus Elan S2
